Low compression
Old Jul 8, 2009 | 03:49 AM
Sho'nuff's Avatar
Sho'nuff
Default Low compression
When reving the engine (L-48) slowly depressing accelerator the engine gets to 2000 RPM and slows down to around 1200 even while still going down on gas pedal. It starts to pick up slowly about half throttle. I have new plugs, wires, hei module. Checked timing , seems to be ok. Checked compression, 70-80 lbs. with throttle open. Added couple shots of oil, no change. Pressure tested cylinders. Can hear some air going by rings but nothing too excessive. No sound in carb or tail pipe. 17in. vacuum. No engine blow by when running even with pcv pulled out. Anyone think it possible the engine may have jumped timing?
Old Jul 8, 2009 | 12:34 PM
Reggie Dunlop's Avatar
Reggie Dunlop
If you did the compression test correctly and really have 70 to 80 psi on all cylinders you have a big problem. Did you crank the engine over until you got the highest reading (usually takes 3 or 4 revs)? I have seen low compression across all cylinders on engines that were overheated. Any chanced that happened?
Old Jul 8, 2009 | 01:24 PM
Sho'nuff's Avatar
Sho'nuff
yes i did,, spun it till it stopped climbing. 5 or 6 revs.
Old Sep 5, 2009 | 03:22 PM
Matt Gruber's Avatar
Matt Gruber
so after 2 months of your best effort, now it won't run at all?
did u adjust the valves?
what do the plugs look like?
does it have a real old cat. converter on it?
how many miles did u drive it recently?
yes, it might of jumped a tooth or 2.
Old Sep 5, 2009 | 05:38 PM
Sho'nuff's Avatar
Sho'nuff
It runs, no power. Checked timing chain and it was true. Plugs are leaf brown, no cat. Not sure about actual miles, someone has been into the engine before, it has a double roller chain. I wonder if they put the rings in upside down? Just trying to get by till next year and its comming out. Adjusted valves also.
Old Sep 5, 2009 | 07:09 PM
Matt Gruber
i see u have made some progress
did u adjust valves running? all i can think of, is they were set engine off, and they are a tiny bit too tight.
Old Sep 6, 2009 | 07:46 AM
Sho'nuff's Avatar
Sho'nuff
yes, valves were tighter than i liked. I backed each one off running till it started clacking. Then, tightened till it stopped plus 1/4 turn more. Some i backed off a whole round before it made any noise.
Old Sep 6, 2009 | 09:29 AM
Matt Gruber
after that, it has 70-80 psi?
have u checked the gauge in another car? sometimes they read wrong!
Old Sep 6, 2009 | 09:35 AM
Sho'nuff's Avatar
Sho'nuff
not in awhile.
Old Sep 6, 2009 | 12:07 PM
falconview's Avatar
falconview
Same problem Cold And Hot? Has the car been sitting?
Old Sep 6, 2009 | 01:25 PM
Sho'nuff's Avatar
Sho'nuff
same cold or hot. Even shot oil in cylinder (one) no change.
Old Sep 6, 2009 | 01:36 PM
midyearvette's Avatar
midyearvette
disconnect the pipes at the exhaust manifolds to eliminate the mufflers and then start the car..see if its better.....
To Low compression
