Best service manual?
Old Feb 12, 2002 | 04:47 PM
mikemac's Avatar
mikemac
Default Best service manual?
Hello, pulled the trailing arms off my '76, got the parts. Now I need a good service manual (already have the AIM) . Read somewhere that Clymers was useless, can someone recomend one? Mostly interested in the specs for bolt torque and end play on rear bearings. Thank you, Mike
Old Feb 12, 2002 | 05:00 PM
Larry B.'s Avatar
Larry B.
Default Re: Best service manual? (mikemac)
Nothing really compares to the factory manuals . You can get them from any corvette supply house like Eckler's. :D
Old Feb 12, 2002 | 06:45 PM
KenSny's Avatar
KenSny
Default Re: Best service manual? (silvervetteman)
Get the GM Service manuals for your year from HELMS.
Old Feb 12, 2002 | 08:07 PM
Paul L's Avatar
Paul L
This diagram may be of interest. I put it up high-res so be patient.
http://temp.corvetteforum.net/c3/pau...arings_001.jpg
Old Feb 12, 2002 | 11:04 PM
lyonsh's Avatar
lyonsh
I have the Chevy, Haynes, and Chilton manuals. The Haynes and Chiltons hardly ever get opened. The Chevy is so dog-eared and greasy I'm going to have to replace it soon. Nuff said? :cheers:
Old Feb 13, 2002 | 10:56 AM
A78Corvette's Avatar
A78Corvette
I also like the Helms manual. :conehead
Old Feb 13, 2002 | 11:03 AM
R. Bruno's Avatar
R. Bruno
Default Re: Best service manual? (A78Corvette)
I have the Chilton (way too general), haynes (better but still general) and Chevy (by far the best for most things). I got the Chevy manual (1974) and 1976 supplement on e-bay for $40 total used in great shape when new it was $100. They are often available on e-bay.
Old Feb 13, 2002 | 11:11 AM
Edzred72's Avatar
Edzred72
I posted a similar topic recently because the GM Passenger Car Manual (only GM issued manual for a 77 Vette) does not give "engine" torque specs. Others have suggested the Haynes Manual as being a supplement to the GM. Guess I'll have to have both!! :cheers: :cheers: :cheers:
Old Feb 13, 2002 | 05:16 PM
Larry B.'s Avatar
Larry B.
Default Re: Best service manual? (Silvr77)
GM manuals that cover component rebuild are called Chassis overhaul manuals and are very detailed. :cool:
Old Feb 13, 2002 | 05:26 PM
Pedro'74's Avatar
Pedro'74
With the Chevy Service Manual, Overhaul Manual, and AIM, even a :conehead like me can pretend to be a mechanic! :jester
-Pedro
Old Feb 13, 2002 | 05:35 PM
GTR1999's Avatar
GTR1999
If you go to flea markets or ebay you can find someof the older manuals. I have a chiltons from 1977 that is 100% better then the newer versions. It goes into depth on differential rebuilding,rear bearings,etc where the newer version tell you to send it out :rolleyes:
I picked up the GM manuals for between $5-$10 at a swap meet.
Gary
Old Feb 13, 2002 | 09:36 PM
ROD NOCK's Avatar
ROD NOCK
Try: http://www.factoryautomanuals.com
Have mainly used, some new. All brands. The Factory Manual is prefered by most. - Good Luck -Rod
Old Feb 14, 2002 | 10:03 AM
Ganey's Avatar
Ganey
Several are good, esp. for the inexp. The Clymer is fine (have 1981 printing).
Old Feb 16, 2002 | 09:26 AM
noskillz's Avatar
noskillz
Default Re: Best service manual? (ROD NOCK)
I just gave http://www.factoryautomanuals.com a try. Overhaul Manual for $20 bucks. Hard to beat that price.
To Best service manual?
