Coolant Overflow
Old Jul 8, 2009 | 01:27 PM
maggie82's Avatar
maggie82
Default Coolant Overflow
What is the correct coolant level for a 1971 350? The side of the expansion tanks reads "Fill 1/2 when cold." Coolant will just overflow through the hose and onto the ground after warmup with the engine off. WHen the car is cold, the tank is empty. What is correct?
Old Jul 8, 2009 | 01:48 PM
thegazman's Avatar
thegazman
Default thegazman
Andy...I have a 79 L-82 which should be similar to your engine. My over flow only raises and lowers approximately 2" from hot to cold. How hot dows your engine run? I'm using a 180 degree thermostat.
Old Jul 8, 2009 | 01:50 PM
maggie82's Avatar
maggie82
Car doesnt overheat at all. The temp gauge is right where it is supposed to be. I have a 195 thermostat. Also on a 1979, I think you have an overflow tank, I have an expansion tank which is pressurized.
Old Jul 8, 2009 | 04:35 PM
Mike Ward's Avatar
Mike Ward
No similarity whatsoever. Pre-73 have internal expansion tanks and no coolant recovery tanks. '73 and up are the opposite.
To the OP: Might be that your rad cap is a little weak.
Old Jul 8, 2009 | 07:10 PM
thegazman's Avatar
thegazman
Default thegazman
Well maybe I'm wrong, but the catalog show the coolant recovery tank for a late 1977 through 1982 as the same tank. So, my 79 should have the same over flow tank as yours. It has a cap, but is not pressurized at the tank. The coolant flows into the tank as the engine heats expanding the water in the radiator. As it cools there is a vacuum which sucks some of the water back into the radiator.
To Coolant Overflow
