Seating rings
Old Jul 10, 2009 | 01:15 PM
Fscott's Avatar
Fscott
Default Seating rings
I'm wondering what the procedure is for seating rings and approximately how many miles it takes to do this. The engine is a 400 with new rotating assembly and I have about 30 miles on it.
Fred
Old Jul 10, 2009 | 03:16 PM
alphamale1906's Avatar
alphamale1906
I'm positive someone with more info will respond. I read this somewhere that the process of seating rings includes engine breaking from varying speeds. I believe you allow light engine breaking from 30mph speeds up to 60 mph. Basically, get the cars speed up to 30 and then allow the car to coast back down to a stop. Follow this process up to speeds of 60. I really don't recall the number of times to do this, but I think I did it a dozen or so times with my big block.
Compared to breaking in the cam, seating the rings is a lot less terrifying.
Old Jul 10, 2009 | 04:55 PM
L88Plus's Avatar
L88Plus
If you have 30 miles on 'em, they're as seated as they'll ever get. Do you burn any oil, any smoke at acceleration, etc?
Old Jul 10, 2009 | 06:21 PM
TimAT's Avatar
TimAT
I agree with L88Plus- to a point. If the rebuild was done using stock type cast or moly rings, then it's as good as it's going to get. If they used chrome rings, it may take a little longer.
Old Jul 10, 2009 | 10:13 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Count me as one who thinks rings take a while to fully
wear in.
The recommendation from the factory for our C3 gen cars was
500 miles.
No full throttle.
General belief was to vary rpms so the seating does not happen
a one rpm.
Yes using engine for braking has a good effect on rings because it changes the load from down to up.
Old Jul 10, 2009 | 10:17 PM
63Nova's Avatar
63Nova
Depends on what type of rings and what you used to soak the pistons before the install. I always soak my pistons and rings with a 50/50 mix of conventional 10w-30 and some conventional ATF.
If you aren't having an issue with blowby or anything though, I wouldn't worry about it. After I heat set the valvesprings I always take my engines out and go through the RPM range on the street with them. After that I really don't worry about it too much.
Old Jul 11, 2009 | 12:16 AM
fauxrs2's Avatar
fauxrs2
A modern set of moly rings as used in99% of rebuilds is IMO going to be broken in long before your cam will a good set of moly faced rings will be broken. On even before that so unless the build used chrome or unfaced cast iron rings I wouldn't worry about if
as for what was reccomended for our cars originally. Well ring technology has come a long way since then. If you aren't burning any oil now then your rings are likely as broken in as they are going to get
again IMO
Old Jul 11, 2009 | 02:03 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I agree that moly rings are good to go.
My ole school mind leaps to ole rings.
Old Jul 11, 2009 | 08:27 AM
blctalon's Avatar
blctalon
When I rebuilt my 406 a few years ago I ended up doing a lot of idling around after the cam breakin. I was trying to fine tune the timing and I had a little fuel leak so I did quite a bit of watching it run to make sure I wouldn't catch on fire from another small leak popping up. Sometime during this process it started to puff a little smoke out the exhaust so I took it out on the road and put it through it's power range, even full throttle. No more smoke after that. You need different ranges of pressure to seat the rings properly but I wouldn't worry too much about a specific agenda to do that, just drive it.
To Seating rings
