Engine began running rough
Today something strange happened to my nicely running original L-48. I drove several miles from home just fine, then refueled. After driving about 20 minutes the engine began running rough when adding more gas (accelerating). For example, I had it in 4th gear and when I pushed throttle down half way, the car accelerated in a sloppy manner and the whole car was shaking in the rhythm of the engine.
It happens in every gear. I also pulled over to an empty parking lot and did some testing. When in neutral and pushing throttle down, the engine doesn't rev like it usually did, but the noise is like so that you can hear the cylinder bangs much better than normally. Kind of like "bam-bam-bam-bam". I'd say like an old tractor.
After revving it for some time, I managed to get it back to normal but it went sloppy again after some minutes of driving. The engine noise was different from usual - I could just hear the cylinder bangs much more whenever accelerating.
I also noticed a remarkable power loss compared to usual experience. I didn't notice a remarkable increase in fuel consumption.
I have two explanations to this myself:
1) I re-fueled at a gas station which I've always used and is the cheapest one around here. I've never had problems before, but I've had friends who told that they got bad fuel from there messing up their engine performance. Did this happen to me today? Could it be bad fuel?
2) Something wrong in the ignition, one cylinder not firing or smth. Perhaps bad spark plug, cable or distributor issue? Actually the cables aren't very old at all and I had new spark plugs installed like 1.5 months ago. Maybe bad fuel made a plug dirty?
Thanks for all the help.
Easy to check. pull valve covers and see if any valve springs are loose to the touch...
You can also run engine(watch out for oil) with valve covers removed and listen for clatter.
Good Luck
I ran the engine with the hood up and revved also, I didn't really notice any unusual noises. I got it running smooth for a while so perhaps a bad spring wouldn't heal itself. If it is a spring, can it be replaced without removing the cylinder head?
I'm now waiting for the engine to cool down in the garage and I will pull the valve covers. I just can't understand how something could break in the engine so easily... I mean a physical part. Usually those things happen during heavy engine load or strong accelerations. I didn't do any of that when it happened yesterday. I don't know how to check for one cylinder not firing properly or perhaps I know but I didn't have anybody to help at the moment so I could listen the exhaust myself. As much as I could hear from the inside when giving gas, it felt like it was missing a bit.
Maybe there really is a problem with one of the spark plugs or cables. I've had the engine idling at 500 RPM or even slightly less for some time because that was the best low idle setting I could find on the Q-Jet. Oil pressure has been OK so no worries about that, but is it possible that long time idling (+ I know my carb runs a bit too rich on idle) could mess up the spark plugs?
I ran the engine without the covers and I didn't notice any unusual noises. I could barely hear the valves, it was pretty smooth. To my untrained eye all the valves were moving in a proper manner and similar to each other. I remember that usually the pushrods are supposed to be rotating - I found at least two valves where they were not rotating constantly but let's say they were sticking a bit (rotating in steps). This probably doesn't have anything to do with the current issue I have though, even if something is wrong about them.
I took one spark plug out which I could reach easily and took a photo. The edge of the spark plug is covered with black cinder and the tip looks like cement, not like metal.
Check the basics. Spark plugs/wires are good? Fuel filter is good? Base timing is still set properly?
Another thing, did you fill up with Ethanol 10%? My car HATES the stuff. The difference in power and sound between non ethanol and the up to 10% mix is huge.
Sounds like a bad plug wire or burned out boot to me
The issue still didn't go away until today when we removed all the spark plugs and found half of them really black and horrible looking. The other half were quite perfect. We measured compression in all cylinders and we got results between 10-11 in all of them, so it seems pretty tight. We then put new spark plugs in and voila, FIXED!
I must say that the engine has never ran so well in my hands. Perhaps it was the ignition cables or maybe there's some issue with the carb mixing a bit too rich mixture at idle. However, I think that if carb was bad, it would affect all spark plugs. It's more likely still an ignition thing.
Oh, and one of my Cherrybomb glasspacks blew out all the glass. What an AWESOME sound I now have
