Fast burn GM heads
Old Jul 12, 2009 | 08:36 AM
Sho'nuff's Avatar
Sho'nuff
Default Fast burn GM heads
Anyone know if you can use standard headers on D- port heads or do you have to have D- port header flanges??
Old Jul 12, 2009 | 09:00 AM
mvette76's Avatar
mvette76
normal headers will work
Old Jul 12, 2009 | 09:44 AM
Sho'nuff's Avatar
Sho'nuff
Good to know! thanks!!
Old Jul 12, 2009 | 11:57 AM
willem wallace's Avatar
willem wallace
Default Fast Burn Heads/Headers
Let me be clear that I am no expert on headers, this is just my .02! While any header may bolt up to the fast burn heads, I assume by the fact you have them, that you are looking for increased performance. If you restrict the exhaust flow from the heads by any appreciable amount, by using the wrong size/shape header flanges, you are robbing the engine of the power that these heads were originally designed to make. Your header choice does not have to have a D-port flange to match your heads, but it should have ports large enough, not to cover the head ports and restrict flow. Good Luck on your search
Old Jul 12, 2009 | 08:25 PM
gingerbreadman1977's Avatar
gingerbreadman1977
willem is right. i have fast burn heads and used d-port header gaskets with d-port headers. now go use oval headers yada yada and you will be cutting off the corners restricting the flow. still work but not optimum .
To Fast burn GM heads
