Cabin Heat
I know installing the collar keeps the heat out of the tunnel where the center console is and thus keeps interior cooler.
Also, make sure your heater control valve is shutting off. It is located on the passenger side of engine in the heater hose line with a small vacuum line from the heater temperature control.
I think I'm also going to get some reflectix and see how it helps. As much as I love the sauna...
So much heat would come through the floor, it was really uncomfortable for cruising, especially in summer.
I had a set of Tri-Y headers with the 2-1 final collector meeting under the floor panels, and that was definitely the source of the problem.
The problem persisted even though I had insulation matting under the carpet.
When I installed my new motor and trans, the heat issue was something I wanted to rectify, as long country touring is what I do regularly.
I sourced some reflective aluminium clad fibreglass matting from a store that supplied the trucking industry. It's rated at 1100*F.
It's used a lot for heat control on turbo-charged diesel trucks.
I cleaned up the exterior (underside) of the firewall and floor pan and used high temperature silicone adhesive, also rated around 1000*F to bond the matting to the fibreglass floor.
I placed it on the underside of my footwell and completely under the trans tunnel and lower firewall.. the idea was to reduce the heat that actually penetrates into the floor by reflecting it. I also have insulation matting in the inside, under the carpet. But I believe the external reflective matt makes a big difference.
The other thing I did, was have a custom set of headers made.
I had plug/lead clearance issues with the new heads, and I wanted slightly bigger primary pipes (1.75") anyway.
The tri-y design was routed to clear everything and provide easy access to the plugs, and ground clearance issues I had before were also addressed. The pipes after the collector now run down on either side of the tranny, in the tunnel, and my feet are now very happy.
We regularly get ridiculously hot periods (last summer we had 14 continuous days above 100*
The current setup is great. Footwell does not get uncomfortable, even after extended 2~3 hour drives in hot summer weather.
Pic's and info ====>: Click Here
George
