Holley Carb ID needed
Old Feb 13, 2002 | 09:40 AM
8TL82's Avatar
8TL82
Default Holley Carb ID needed
Which rebuild kit would I need for this Holley carb?
D8PE-9510-ZA
List-8418
I believe it's a 750 cfm.
Old Feb 13, 2002 | 10:23 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: Holley Carb ID needed (8TL82)
Are you sure of those numbers?
part# should begin with 0-**** and model 8418 can't be found :confused:
Old Feb 13, 2002 | 10:31 AM
8TL82's Avatar
8TL82
Default Re: Holley Carb ID needed (yellow 72)
Absolutely. Just checked again and verified the numbers. It also has a Ford Motorcraft tag on it. Don't know if this helps or not.
Old Feb 13, 2002 | 10:42 AM
8TL82's Avatar
8TL82
I brushed some more gunk off to claify those numbers (which are right) and found some more under the List-8418. "2329". Does this help?
Old Feb 13, 2002 | 11:22 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
That's a Holley OE Ford carb. I don't have any info on them but I'll check around.
Old Feb 13, 2002 | 01:57 PM
Tom454's Avatar
Tom454
You probably will not find info on that carb from Holley.
A customer of mine had a 1968 Cougar and he bought an Edelbrock manifold, and pirated a "Ford" Holley off an abandoned Ford van with a 351 in it. He asked me to rebuild the carb for him & install the intake & carb. I had a HE LL of a time getting info on that carb.... with no application to work from. I had to go to Ford to get the kit... it was $75... and that was ten years ago. Holley & Ford have an agreement... you can't get the info or kit from Holley.... only from Ford. Isn't love wonderful?
If you can convince one of the air-heads at your favorite auto parts store to actually look in a book (eeeegad... he'll have to think), he might be able to use the Ford number to come up with a kit for less than $100.
Good luck.
[Modified by Tom454, 12:59 PM 2/13/2002]
Old Feb 13, 2002 | 08:03 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: Holley Carb ID needed (Tom454)
Tom, your not kiddin' just out of curiousity I even searched the ford resto sites and found a lot of 9510 Ford/Holley muscle carbs from the late 60s and early 70s but nothing like 8418...yep good luck :cheers:
To Holley Carb ID needed
