Ive recently had an issue with a lifter i believe is sticking. I removed the intake and exposed the lifters, while there ive considered changing all the lifters and rods which is cheap and simple. However, after reading the thread entitled "change lifters?" im reconsidering my actions. Will changing the lifters really cause possible damage to the cam shaft? as high as a 50/50 probability of damage?
the answer to your question is yes and yes. A new cam and lifter starts wearing as soon as the engine is started. They develop a wear patten that in particular to that individual lobe and lifter foot. If you change one without the other the wear pattern has to start all over again and you run a risk of the lobe or the lifter going away.
After that, I'll tell you that while you ARE taking a chance, I have replaced one lifter on a cam back in my dealership days on cars under warranty and gotten away with it as far as I know. Did it really work over the long term? No idea. But it was all that warranty would pay for at the time because the cam was not already flat.
so what do you recommend, pull the lifters, clean them and put them back in the way they came out? will i also run a risk by replacing the rods? Or just blow them with air where they are and only adjust the valves? Being a shade tree/weekend mechanic i rely on ya'lls advice.
yes you should keep the lifters in order to line with original lobes.
As stated, it is a service item that has been replaced and can wear in with no problem.
You should run it like a new cam break in.
Also as stated, it might not wear right and flatten a cam lobe.
Tough choice.
Examine the questionable lifter for debris.
clean it with some solvent and reprime with oil.
The engine developed a ticking sound and after eliminating all possible causes the noise was believed to be a lifter. A quart of trans fluid was put in and the sound went away. Recently, the car ran out of gas, and coasted to a stop. After refueling and starting the engine, a great deal of smoke came out. When i turned the car off, it wouldnt stop running. So we believe a lifter had stuck holding a valve open.
Uh, the cam holds valves open.
How tight did you adjust them?
OK, these are a bunch of unrelated symptoms from my perspective.
If a valve was held open - you'd have other problems other than run-on.
IMHO I'd loosen the rockers and squirt just a touch - just a touch - of carb cleaner down the pushrod. Adjust the valves carefully, and get go through a couple of oil changes at 1K intervals.
Ok,, i guess my course of action at this point is to clean the lifters, put it all back together, change the oil, and see what happens, oh, and adjust the valves. Anything else that i can do while i have the intake off?
prob not DB . even your pushrods should go back in the right locations and the same way up and down. dont know how accurate you kept everything in order but dont panic if you didnt.i would recommend using penrite run in oil once you get it all back together just to be sure as it has none of the friction modifiers in it that standard oils have. do you have a good formular for resetting your rockers?
Just to clear things up. Installing new lifters on a used cam works fine as long as the cam is in good condition. The chances for lobe or lifter failure go in this order:
1) New cam and new lifters - greatest probability of failure.
2) Used cam and new lifters
3) Used lifters and new cam
4) Used cam and used lifters - least probability of failure.
As long as you use break in lube, and follow sound break in procedures, new lifters on a used cam is OK.
I worked at a Chevrolet dealer in the mid-70s and it was a common accepted GM practice to replace a single lifter at a time.
An open valve will not cause an engine to not stop running.
A lifter will not stick and hold a valve open.
Sounds to me like you put some bad gas in it after it ran out which caused run-on or dieseling.
Apparently you have a bunch of people who know nothing about engines, making wild guesses as to what happened.
theres always the possibility of wild guesses, as of right now, i have only taken the intake off and exposed the rods and lifters, none removed yet. Ive had one fellow tell me to run it till it breaks and then you'll know whats wrong...id like to think he was joking. When the car ran out of gas, and coasted to a stop, what would have caused so much oil to have gotten into the cyclinders upon restart?
There are 2 places oil can get into the combustion chamber, the rings or the valve seals. The seals are easiest to check. I wouldn't take out the pistons unless absolutely necessary.
OK.....as you haven't taken anything apart besides the intake, I'd go get some gaskets and some rtv and re-install the intake,distributor, and carb. Get someone who knows what they're doing, and confirm whats going on with your engine. Run the engine and isolate the noise, and then re-adjust the rocker and see if the noise comes back It could be as simple as a lifter adjustment, or as bad as a flat lobe....but confirmation is a must
From what I can tell by reading his posts, the noise didn't come back. All it did was smoke some after he put gas in it, then it was dieseling when he shut it off. None of these symptom point towards the cam and lifters.
