just bought a C3 with a 400ci HELP!
Mods: {drivetrain has approx. 3,000 miles on it since new}
-400ci small block
-780 Holley carb
-Brodax aluminum heads
-Manley Thunderstick cam
-Roads pump up lifters
-1.5 + 1.6 ratio Rockers
-Ceramic coated long tube headers (possibly custom)
-3 speed auto (will have to double check with my uncle exactly what it was)
-2500rpm stall converter
-shift kit
-3;90 gears (LSD)
-Wheels are original 15's w/ 225-60's
i saw the car...the only problem mechanically it has is that when you start it up it takes a while for it to heat up to stay running on idle....but once it does, this thing is a beast!
i spoke to a friend who had a 383 swap in his 79 and had the same problem and he said he fixed it with a tune and something about fixing the fuel regulators to lean or rich(dont know wat that means because im kinda new to this stuff). Also he said the engine gets real hot because the hood is sealed and lets no air in to the engine...he recomended a electric fan to have running at all times to keep the big 400ci cool.
please guys, i have read up on here and you guys know your stuff. let me know if this is what i stated or a major problem? I need to know asap. thnx
My opinion, you are over your head with this one and I would pass, you are going to be spending allot of money trying to find someone to fix it for you. Sorry for being so blunt
-400ci small block
-780 Holley carb
-shift kit
-3;90 gears (LSD)
[B]i saw the car...the only problem mechanically it has is that when you start it up it takes a while for it to heat up to stay running on idle....but once it does, this thing is a beast![/B]
he recomended an electronic fan to permantly have running to help cool the engine.
You seem to be having difficulty understanding a cold idle problem which is most likely a simple choke adjustment. I think you would discover an overheating problem is much more complex issue especially on a modified 400 small block. Read some of the post on this forum for more insight into what some members go through to find the problem. If you think this is a simple solution, why not say to the current owner: "fix the overheating issue and we can complete the sale". Let him install electric fans and prove there is nothing else wrong. If you buy this car with an overheating problem I hope you get lucky and find a simple solution.
Here is my top ten list
1. Open the hood and look down in front of the rad. Vacuum/blow out any lint or trash that has accumulated.
2. Make sure rad is topped off and some kind of green/red/yellow color.....not a rusty color. If it's rusty a rad flush is in order.
3. As mentioned previously, the lower spoiler is extremely important for directing airflow up into the rad....if its not there get one. They are easily broken by parking curbs.
4. Test your thermostat in a pot of water with a thermometer. It should start to open at the posted temperature on the thermostat. If it doesn't replace it. I'd recommend a 195*
5. Look at the rad hoses and make sure they are good. Any bulging at the clamps is a sign of a worn out hose. Replace them.
6. Corvettes come with foam pieces that surround the rad on the sides and top. They seal airflow leaks. Make sure they are there.
7. Make sure the fan shroud is in place, and in good shape....if its not fix it up.....this is the "ductwork" so to speak that connects the fan to the rad. No ductwork no cooling.
8. Drop in an ounce or two of Downy fabric softener. This will reduce the surface tension of the water and allow the coolant to flow through the rad with fewer bubbles in the mix. Makes for better cooling. Works the same as 40 below or waterwetter.
9. If your still having troubles pull the rad and have a rad shop look at it, some of the passages may have become plugged, by who knows what's been poured in there in the last 30 years. They can fix that.
10. Time for a new high effency aluminum rad.....The kind where each individual louver has louvers. Your problems should now be cured.
Having to ride the pedal for a few minutes until the engine gets some heat in it isn't unusual for a larger cam engine.
Hope this helps.....happy wrenching
The idle circuit on the Holley is most likely calibrated for a 350. The IFR's are .031 stock. I went to .035's which are a bit rich, but I can start this stone cold and drive it with zero warm up. I don't even have a choke.
My uncle installed an electric fan on his 52 pickup and just mounted a switch in the dash so he could control it himself... of course he can leave it on an drain the battery or he can forget to turn it on when the car is hot.... I always liked the thermo switches better.
be carefull with adjusting your carb, you can blow/burn up the motor if you run it too lean. make sure you have someone who knows that they are doing at least watch you to make sure you don't kill it.
