No power to alternator wire
Old Jul 14, 2009 | 11:15 AM
Vetteitbe87's Avatar
Vetteitbe87
Default No power to alternator wire
It would get pulled out sometimes while driving when the engine would rock. Motor mounts are good the wire is just too short. But now it has no power coming from the battery and the wire is fed all up into the frame and body just so I cant get to it. This is coming directly from the battery correct? And would it be easier to just run a new wire?
Old Jul 14, 2009 | 11:40 AM
GruntyPants's Avatar
GruntyPants
Hey, and greetings from Kennesaw!
Do you have power to the wire with the car off? Does the wire from the alternator go straight to the horn relay? I'm kind of fuzzy on the wiring after '69.
Old Jul 14, 2009 | 11:45 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Yes, that wire goes to the battery, or more correctly to a junction box by the battery.
At least that is the case if your car was originally equipped with a tape player.
If you would like to repair it "the right way", you can buy a replacement harness from various places.
Here is one from Zip http://www.zip-corvette.com/Zip/prod...2847E2E725C966
Otherwise you could just run a new wire.
Old Jul 14, 2009 | 11:57 AM
...Roger...'s Avatar
...Roger...
Once again GM didnt do a very good job of making this "battery charge" wire clear in the troubleshooting manual.
Driveshaft is there a fusible link in the battery charge wire,the 82 book shows there is ? It looks to me like it should have one on both ends.
Old Jul 14, 2009 | 12:39 PM
DRIVESHAFT's Avatar
DRIVESHAFT
There is not one on my car, but my car has not always been taken perfect care of before I bought it.
Looking at the pictures of the harness from various vendors, I dont see one.
The pic below is from Corvette central - It is labeled "ALTERNATOR - TO BATTERY HARNESS WITH STEREO TAPE PLAYER "
The front lighting harness is different as well based on tape player installation. The non tape player harness includes alternator wiring.
To No power to alternator wire
