DISTRIBUTOR WORRIES
Old Feb 13, 2002 | 12:38 PM
Mr.Gearhead's Avatar
Mr.Gearhead
Default DISTRIBUTOR WORRIES
Hi all,
First off, thanks for all the help so far. I have most of all my issues worked out and I have not even taken the car apart yet. I know I will have problems when disassembling, but atleast I will have all my parts figured out!
How much would I benefit from HEI? I have a Petronix ignitor instead of points and it seems to better. I am worried that my rebuilt motor will need more spark than I have. Should I just go with a MSD box and big coil? I am building the motor from Chevy High Performance. (http://www.chevyhiperformance.com/editorial/article.jsp?id=46370& viewtype=text). What do you guys think? Recommend? :confused:
Old Feb 13, 2002 | 01:15 PM
73-454's Avatar
73-454
Default Re: DISTRIBUTOR WORRIES (Mr.Gearhead)
I installed a used GM HEI unit in my 73 454 and it works perfect. I happen to have a spare HEI unit. I would be willing to trade or sell.
Old Feb 13, 2002 | 02:18 PM
Mr.Gearhead
Default Re: DISTRIBUTOR WORRIES (73-454)
Did you hook up the factory tach? I would like to retain my factory tach. I really don't want to buy the HEI with a tach gear.. it is like $500. I just don't know if I need a HEI?????? :crazy: :confused: :eek:
Old Feb 13, 2002 | 02:30 PM
Alwyn678's Avatar
Alwyn678
Were they not able to run 400 + HP motors on points back in the 60's and 70's?? hmmmm if they could do it then ..I guess I can do it now :cheers:
Old Feb 13, 2002 | 07:25 PM
Mr.Gearhead
Default Re: DISTRIBUTOR WORRIES (Alwyn678)
Alwyn- I know they used to run big numbers with points, but they also used to run with bias ply tires, that does not mean I what to use them. I was looking for the members that switched to HEI and if they saw it as an advantage over pts. I know pts can sometimes be tempermental and I thought my power increase would demand to much for my existing ballast coil setup.... Thanks for the sarcasm... it made me laugh :D
Old Feb 13, 2002 | 07:30 PM
redvetracr's Avatar
redvetracr
Mr.Gearhead,
The HEI is probably better than your stocker with points but a downside is no more tach, I like the GM transistorized with MSD box and coil (but thats just me) and a used TI distributor is worth almost as much as a new MSD (at a good deal). If you want to sell the factory tach drive distributor i am a buyer. .....redvetracr
Old Feb 13, 2002 | 10:18 PM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
A few years ago put complete MSD system on my 66 427, mechanical tach drive Pro billet distributor with vac advance , box , coil & wire,,,,,,,very satisfied instantanious starting, smooth idle & plugs can be gapped at .45 i have not touched ignition system for 4 years :cheers: anyways worked for me.........note bought system from SUMMIT :flag
Old Feb 14, 2002 | 02:49 PM
Mr.Gearhead
Default Re: DISTRIBUTOR WORRIES (redvetracr)
I am think of getting rid of the Petronix setup. I am REALLY thinking of buying the tach drive HEI. I want the technology and the car to look original on the inside..
REDVETRACR, if I do decide to sell it, I will include the petronix ignitor with it . How much do you wanna pay... seriously! I not looking to gouge a fellow member.... i'll sell it cheap! my email is bendera1@attbroandband.com
Old Feb 14, 2002 | 02:54 PM
Alwyn678's Avatar
Alwyn678
Cool My car had HEI when I bought it and I found an old style tach drive distributor with points and It runs just as well.....if not better..I tried Pertronix but it died on me in two months (ignitor II).....Now I gotta go find some Bias ply tires....NOT :cheers:
To DISTRIBUTOR WORRIES
