Radiator Lower Water Neck
Old Jul 14, 2009 | 09:45 PM
c3corvette77's Avatar
c3corvette77
Default Radiator Lower Water Neck
Ok, here's my problem of the day for the old 1977. The metal tube coming off the bottom of the radiator is leaking at the weld. Second time it's happened, I repaired it once already. When the lower radiator hose is connected it's actually touching the top of the front anto roll bar. I'm convinced the motion of the anto roll bar is flexing the water neck and causing the leak. The question I have is, does anyone elses lower radiator hose touch the top of the bar? Do you think the radiator core support rubber isolators are just shot and the radiator is sitting too low? I'm even considering asking the shop if they can miove the water neck up 1/4 inch for clearance. Any insight would be cool.
Old Jul 14, 2009 | 10:11 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Is it the factory radiator? Have you changed anything on the front of the car lately? If not than it is likely the front has settled, could be a few issues that combined could have caused your issue. I shimed my roll bar with 1/4" aluminum plate (cut to fit) to lower the bar down to give the lower radiator tube some room.
Neal
Old Jul 14, 2009 | 10:28 PM
c3corvette77
i doubt it's the original radiator, plastic drain valve.... i have not replaced anything up front so it's not something i did. i considered shimming the roll bar down too.
Old Jul 14, 2009 | 10:45 PM
Mad Vette's Avatar
Mad Vette
I bet thats your problem the lower water intake on my 71 is dented in on purpose (from the factory and Dewitts) to clear the stabilizer bar.
Old Jul 14, 2009 | 11:08 PM
c3corvette77
so what's the consensus? should i change the lower radiator isolators, which i think i'm going to do anyway, move the water neck, shim the roll bar? all 3?
Old Jul 15, 2009 | 12:25 AM
OMF's Avatar
OMF
I'd shim the anti-roll bar.....oh and while your at it replace the rubber mounts with poly....well you can't have a poly/ rubber mix so you might as well change the upper and lower a-arms to poly.....and paint the a-arms while there out.....oh crap.... that means the frame needs painting....and you can't paint the underside of the frame without doing a frame off.........better get some....no... lots of beer
Old Jul 15, 2009 | 07:38 PM
chevymans 77
You may also be able to loosen the two large bolts that attach the core support to the vacuum canister (bellow the radiator) and lift the nose a little than tighten the bolts back, this will support the nose and raise the core support and radiator a little. I also ran across an issue close to this with my car only one fender was higher than the other, I looked for what was causing this for a while than one day I loosened the two bolts for some other reason and just happen to notice that the fender clearance had evened out. I raised the front a little and tightened the bolts and the front stayed were I had set it.
Not saying this is your issue just suggestions on things to look at.
Neal
Old Jul 15, 2009 | 08:47 PM
noonie's Avatar
noonie
Neal
Those 2 bolts are made for adjusting the coresupport around a little. The hole in the bracket is much larger than the bolt size and has toothed washers to grip.
Here is a pic of the fit of a 77, only about 1/8" clearance on this one, with no probs.
If that's not enough, shim the bar mounts.
Old Sep 15, 2009 | 09:28 PM
c3corvette77
UPDATE!!! i pulled the radiator out and took it to the repair shop. they actually had a 76 vette up on the lift and i was able to show the guy exactly what i needed. they were able to tweak the water neck and get me 3/4 inch clearance before i put the lower hose on. i got new rubber isolators for thr bottom and those coupled with the tweak in the water neck i have over 1/4 inch clearance on the swaybar. i looked at loosening those 2 bolts but i had visions of breakage. i road tested the car sunday and, wait for it..... NO LEAKS!!! what a concept....
To Radiator Lower Water Neck
