From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
454 bogs at WOT - ???
My carb was rebuilt by Lars and my timing is set accordingly. Idles great....revs good.....but It bogs "momentarily" when I stomp it. I seriously doubt it's a carb problem. After it "catches up" its OK but I just cant get the bog out of it. This is a TOTALLY rebuilt stock spec LS4 - 454.
Any suggestions?....I hate to just start messing with stuff.
If Lars rebuilt that carb, $100 says it's right on and the secondary spring is set correctly. He runs his rebuilds on his car to test them. (or he used to)
Check your timing and advance systems- tons of threads about how to adjust and recurve the distributor for best performance. I'd suspect that the advance is not quite where it should be- either the weights are sticking or the vacuum advance is done.
How long ago was the carb rebuilt?
The spring tension on the air valve is unlikely to change once set.
Since chances are very good that Lars set it properly, you might not want to adjust it just yet.
The air valve opening is also delayed by the rod that connects it to the choke pull off.
When operating correctly, the vacuum has to drop before the air valves can begin to open.
If the pull off is not working, the air valves can open too quickly causing a bog.
yep..i would check the pull off or the vac line....
I'm pretty sure you said you got a Q-jet on there.
Sounds exactly like a carb adjustment problem to me- air valve that is. The only thing the air valve does is give you a smooth transition into the secondaries opening. If it only bogs when you "stomp it", it's probably the air valve needs tuned. You didn't say, but I'll assume the bog started after the rebuild. If it ran fine before, unless Lars marked exactly where the air valve was set before tearing it down, he probably set it to the usual 1 full turn after the rebuild.
It's easy to adjust once you know where it is, and you can always set it back where it was to start worst case. I can probably talk you thru it if you want instructions.
"Rochester Carburetors" by Doug Roe is a great book to get. It was mostly a black box to me until someone finally talked me into getting it. Now it's no big deal to tear it apart.
Thanks Guys....I agree.....a carb rebuilt by Lars is ususlly "right on".....I think I will start with the timing. The dist probably needs rebuilt, as I can hear the tach drive gear "buzzing" which indicates the shaft is pretty worn.
Speaking of Lars......is he still around? I haven't ""seen" him here in a while. I have been absent myself with a fresh double bypass last February. Getting old sucks but beats the alternative!
You're in Georgia, Lars is in Colorado. Likely a big elevation difference. If Lars set the carb for his elevation you may need to adjust it for yours.
