Car is killing me
Old Jul 15, 2009 | 05:00 AM
lowes-yellow77's Avatar
lowes-yellow77
Default Car is killing me
well i started this problem myself but it was a long one...
The car was burning rich so i adjusted by ear and it worked well no more burning rich but jjust in case i hooked up a vacuum gauge and it was really wierd it fluctuateted really fast just a small amount between 16-20 on the gauge.
just to answer some questions that will be asked i unhooked the vacuum advance and plugged the carb off where the advanced was hooked up.... i used the the vacuum off the manifold i tried reving it up and the fluctuations get faster and more spread apart
IM LOST i thought it was the valves so i tried to tighten ot loosen them and now at idle the rpm fluctuates from 650-780 every 2-3 seconds
PLEASE HELP
Old Jul 15, 2009 | 06:53 AM
baxsom's Avatar
baxsom
http://www.secondchancegarage.com/public/186.cfm
how to interrupt what your vacuum gauge is telling you.
yours sounds like scenerio 15
Old Jul 15, 2009 | 10:02 AM
SIXFOOTER's Avatar
SIXFOOTER
fluxuating needle is an intake leak.
and I think the term is Interpret
Old Jul 15, 2009 | 12:27 PM
1nicecorvette's Avatar
1nicecorvette
shouldn't you be taking the vac reading from a port higher then the intake such as the brake booster on back of the carb? fluctuating vac reading "without" revving the car would be a leak
Old Jul 15, 2009 | 05:24 PM
SH-60B's Avatar
SH-60B
I believe the vacuum signal is the same everywhere the vacuum exists.
Old Apr 11, 2012 | 09:33 PM
lowes-yellow77
old thread but in the end i had 3 flattened cam lobes
Old Apr 11, 2012 | 09:43 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
why would you want to interrupt what the vacuum gauge tells you?
sorry couldn't resist spell check strikes again....
To Car is killing me
