help interpret vacuum readings, please
Old Jul 15, 2009 | 08:30 PM
cherrybombc3's Avatar
cherrybombc3
Default help interpret vacuum readings, please
I am chasing my tail trying to get my 383 to idle. I know it's going to be somewhat poor, but it konks out when I put it in gear. WHY??
Here is what I have:
383 stroker (69 L-46 block)
CC XE274 cam
KB 10.2:1 pistons
Dart eagle SS heads
Long tube hookers
duals w/ cross over pipe
Holley St. Avenger 83-670 carb
TCI Super St. Fighter TH-350 W/ Hughes GM2500 T-Converter
3:55 gears
MSD Pro billet dizzy
Black 18 deg bushing
1 hvy & 1 light silver springs
MSD 6AL BOX
Plugs gapped @ 0.035" (AC R45TS)
DIAGNOSIS
In park I can get it somewhat smooth or at least idle @ 1000-1100 rpm
If I try to get 900 in park she wants to die.
At the 1000 in park idle, when put in drive she drops to aprox. 400 rpm and dies
If I get a good "in drive" idle (lumpy) but 6-700 rpm, then put it in park, she climbs to aprox. 1500 rpm
Idle vacuum reading off full manifold vac fitting on carb = 12"-13"
when throttle is snapped it drops to aprox. 3"-5" and on deceleration it climbs to aprox. 18"
Initial timing = 16 deg
Any ideas???? Or is this a Holley P-Valve issue due to low vacuum?
Any discussions would be appreciated.
Old Jul 15, 2009 | 09:09 PM
DZRick's Avatar
DZRick
I wish I could give the member that posted this credit for doing so but this was posted earlier today. You might find it helpful.
http://www.secondchancegarage.com/public/186.cfm
Old Jul 15, 2009 | 09:14 PM
cherrybombc3
I did see that & utilized the website, but the readings are for stock engines it appears. With a performance cam I'm not sure how well they apply? It claims with a performance cam you should have 15" @ idle. I certainly don't have that. Thanks for the tip but I am still a wee bit lost.
Old Jul 15, 2009 | 09:25 PM
Gordonm's Avatar
Gordonm
That cam is not that radical for a 383. Your idle vacuum is normal. I run at about 8 to 9 inches of vacuum but I also have a stick in my car. I also had to run 18 to 20 degrees initial advance. Are you running vacuum advance?
What PV are you running?
Old Jul 15, 2009 | 09:30 PM
cherrybombc3
Yes, I do run a vacuum advance, I actually switched the MSD B-26 can to a B-28 now. The PV is the stock one that came in the St. Avenger # 6.5
Old Jul 15, 2009 | 09:32 PM
baxsom's Avatar
baxsom
its ok,
you can give me the credit, i dont mind.
with a performance cam does the general rule of thumb to diving vacuum in gear and get a PV a few points under that.
chances are the standard holley 6.5 will work.
also what is the secondary throttle plate set at?
Old Jul 15, 2009 | 09:37 PM
cherrybombc3
A little research shows my PV to be a 65.
Old Jul 15, 2009 | 09:41 PM
DZRick's Avatar
DZRick
Originally Posted by baxsom
its ok,
I didn't only because I couldn't remember who posted it. I did save the link.
Old Jul 15, 2009 | 09:45 PM
Gordonm's Avatar
Gordonm
I hada problem running a vacuum can on mine. At a stop light when my idle was set at 850 to 900 rpm the vacuum was around 8 inches. It would idle for a little bit but it was on the brink of dropping out the vacuum can and just a little would drop the can out and the idle would drop and the motor would stall out. I then ran no vacuum and it ran fine. Then I put it on a ported vacuum signal and it would only pull in the vacuum at a cruise rpm. It would idle OK and I was getting the advance at cruise. I have since switched out to FI and the timing is controlled by the computer. You might try to block off the vacuum and set the initial at about 18 to 20 and see what happens.
The 6.5 PV should work fine at the vacuum you are running.
Phil Zell's Avatar
Phil Zell
ttt
Old Jul 15, 2009 | 09:57 PM
cherrybombc3
I could plug the can & bump up the initial to 18 & see what I get, if I bump the initial to 20 with the centrifical bushing allowing another 18 deg due to the MSD black bushing (largest one) I would be at 38 full advance. Is that not too much?
Old Jul 15, 2009 | 10:06 PM
Gordonm's Avatar
Gordonm
Yes that is a little much. I ran the black bushing and as I recall it did not quite give me 18 centrifical. Just try it and see what it does for your idle.
Old Jul 15, 2009 | 10:10 PM
cherrybombc3
I will & report back tomorrow. As for Baxom's earlier question regarding what my seconday throttle plate is set at. I don't know, didnt mess with that?
Old Jul 15, 2009 | 10:54 PM
glen242's Avatar
glen242
I am using a XE274H cam in my 383. Vacuum at idle is 13", just what CC predicted.
Old Jul 15, 2009 | 11:21 PM
cherrybombc3
Did you have any issues obtaining an idle? Can you expand on your set up/ Carb, timing, vac advance?
Old Jul 16, 2009 | 08:50 AM
cherrybombc3
TTT
Old Jul 16, 2009 | 05:19 PM
glen242's Avatar
glen242
No idle issues.
12 cc dished pistons
'0' decked block
Performer RPM intake with modified/rebuilt stock Q-Jet
TF 23* heads - 64 cc - 0.041 head gaskets
Dynomax ceramic 1 5/8" headers - chambered exhaust
And, of course CC XE274H cam
HEI distributor - 35* timing, all in by 2600 RPM +
16* vacuum advance from manifold
I had to change vacuum cans to get the advance to pull max. advance @10 - 11" vacuum
I don't care what initial timing is, only max!
4-speed idles @ +/- 900 RPM.
Static CR is calculated @ 10.30, dynamic is 8.3. Running 89 octane BP for 3 years without problems.
Any more questions?
Old Jul 16, 2009 | 08:45 PM
cherrybombc3
No idle issues.
'0' decked block
Any more questions?
Thanks for the info, sounds very close to my set up.
What plugs & gap are you running?
You know I am on my 3rd carb now, an EB 750 performer, a Ho;;ey HP 750 & now a Holley St. Avenger 670 and I've tried no vac can, a B26 can & now a B-28 can & this thing wont seem to run right. I had the best luck with no vac can and a Holley HP 750, it idled but seemed like it only had 350 crank HP. I even now have a burp in the mufflers when I shut it off hot. Not a backfire or pop, just a burp per say, like a double boom boom, kinda muffled. Not a bang or a solid clank or pop, but a small double detonation almost. Funny thing is it does this aprox. 2-3 seconds after turning the key off!! I now beleive I'm chasing the wrong problem. WTF MSD Ignition issues or valve timing??????
To help interpret vacuum readings, please
