350 Starter Defect...BE WARE
Old Jul 16, 2009 | 08:45 PM
yellowC3's Avatar
yellowC3
Yea i put the starter brace on today and pop went another nose cone. Im done cranking the car.. everything else from now on im going to leave the solenoid off.
Old Jul 17, 2009 | 04:26 AM
bbdude454's Avatar
bbdude454
I am having to pull my motor because of the same problem and it is a 400 small block. I have tried 3 different starters and each has done the same thing, grind and then not make contact with the flywheel. I even got under the car while it was safely supported and with my bump start saw that it wasn't hitting the flywheel. Adjusted the starter worked a couple starts and then just spins the bendix. I have tried shimming and that didn't work.
David
Old Jul 17, 2009 | 07:09 AM
...Roger...'s Avatar
...Roger...
Thats a good idea. There are different flywheels and starters and combinations. I have had cars in with noisy starters but they always seem to be rebuilt with new noses or new starters. I wonder if over the years the new starter noses are the problem. I've always been in the habit of rebuilding the starter instead of replacing if the starter sounded good. I have bought rebuilt starters and installed them and when they make noise I have returned them until I get one that sounds good.There does seem to be a difference in some brands of starters.I wonder if using an old original nose would get you closer ? Yellow is your starter nose aluminum or steel, straight bolt pattern or staggered ?
Old Jul 17, 2009 | 09:09 AM
Clams Canino's Avatar
Clams Canino
With this plan; you'll find your fuel consumption and maintenence costs go way down.
-W
Old Jul 17, 2009 | 11:46 AM
yellowC3's Avatar
yellowC3
DWncchs,the noses on these starters are aluminum. It is the diagonal bolt pattern. Im wondering if i need an original nosecone myself. I was debating pulling the flywheel but i just dont know what to do right now. you said there are different starters/flywheels/combos. could my flywheel really be the problem? I dont understand how any 168 tooth flexplates could be different in diameter.
Old Jul 17, 2009 | 12:10 PM
...Roger...
I dont either and trying to measure one for a comparison for a .050 difference is probably going to be tough. I think you should try and see if you can find a variation in the nosecones by leaving the solenoid off and measuring the clearance between flywheel and bendix gear.
