Engine RPM's Increase When Brake is Applied
Old Jul 17, 2009 | 03:45 PM
Fishndude's Avatar
Fishndude
Default Engine RPM's Increase When Brake is Applied
Any idea what would cause my rpm's to increase when I apply the brake in neutral while idleing? I thought maybe my brake booster was shot but my brakes are actually working great..
Old Jul 17, 2009 | 04:16 PM
...Roger...'s Avatar
...Roger...
Its a temporary vacuum leak while the booster is refilling.
Old Jul 17, 2009 | 05:25 PM
Fishndude's Avatar
Fishndude
So thats normal because it will continually do that if I keep pressing on the brake. The increase is about 200rpm.
Old Jul 17, 2009 | 05:29 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Mine does the same thing, but also in gear.
Old Jul 17, 2009 | 06:05 PM
Duke94's Avatar
Duke94
I would suspect a bad booster causing a massive air leak.
Gary
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: I have power brakes in my two. Neither surges as described.
Old Jul 17, 2009 | 06:17 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I agree that it is not a normal condition and a vacuum leak is
appropriate diagnosis.
Time to check the hoses and fittings.
To Engine RPM's Increase When Brake is Applied
