STARTER QUESTION
Old Feb 13, 2002 | 09:18 PM
slide's Avatar
slide
Default STARTER QUESTION
Anyone know how many shims should be between the starter and the block on a 75 350. My starter didn't have any and the bendix just slips on the fly wheel when you turn the starter over.
SLIDE :confused:
Old Feb 13, 2002 | 09:26 PM
SharkAttack's Avatar
SharkAttack
Default Re: STARTER QUESTION (slide)
Have you checked the flywheel for wear? After a number of poor engagements, the flywheel teeth will wear and cause the starter gear to "slip" (thereby causing that wonderful, screaching, metallic, sprocket-tooth-grinding sound).
Old Feb 13, 2002 | 09:30 PM
slide's Avatar
slide
Default Re: STARTER QUESTION (SharkAttack)
The flywheel is showing wear but I don't think it should be worn to the point of not catching on the starter. This enginge was rebuilt just before I bought the car and I think that the guy forgot to put the shims between the starter and the block. At least thats what I'm hoping!
Old Feb 13, 2002 | 09:32 PM
lbell101's Avatar
lbell101
If its not engaging at all, it's probably the bendix not kicking out far enough. Cheap and easy to change.
Old Feb 13, 2002 | 09:33 PM
slide's Avatar
slide
Default Re: STARTER QUESTION (lbell101)
It is engaging but just slipping on the flywheel :eek:
Pete79L82's Avatar
Pete79L82
No shims is as deep into the flywheel ring gear as the starter can go. If you add shims the starter will engage nearer to the outer end of the ring gear. It sound like you may have a bad starter drive (Bendix).
Old Feb 13, 2002 | 09:34 PM
Dalannex's Avatar
Dalannex
No shims and you're not engaging??? Sounds like you don't have the right starter for the flywheel you're running.
Old Feb 13, 2002 | 09:37 PM
slide's Avatar
slide
Default Re: STARTER QUESTION (Dalannex)
Ok, how do I know if the starter is correct for the flywheel?
Old Feb 13, 2002 | 09:38 PM
lbell101's Avatar
lbell101
Has it engaged before?
Old Feb 13, 2002 | 09:39 PM
slide's Avatar
slide
YEP
Old Feb 13, 2002 | 09:42 PM
lbell101's Avatar
lbell101
OK - so that starter was engageing before. There are no shims. The teeth on the flywheel are there. Then I'm sticking with a bad bendix diagnosis! :)
Old Feb 14, 2002 | 12:02 AM
WATTAC's Avatar
WATTAC
Are you actually trying to turn the engine over with the starter, the starter is rotating (you can hear and feel it), the solonoid has moved the bendix forward into the flywheel (you see/feel it) and then the engine doesn't rotate??? If all that's true then I agree it's the bendix. Have you tried to rotate the bendix by hand. It should rotate easy in one direction without turning the starter, but if you try to turn it the other way then it should engage and turn the starter. Also "hit" the starter to make sure which direction it rotates in and make sure the bendix "locks" when it turns in this direction and does "free-wheel". I suppose you could have the wrong bendix if you've just replaced it.
Oh, by the way have you replaced the flywheel with one that's smaller than the original????
Fresh out of ideas after all that.
Andy
Old Feb 14, 2002 | 08:58 PM
slide's Avatar
slide
Default Re: STARTER QUESTION (WATTAC)
PUT A NEW BENDIX ON TODAY, WILL PROBABLY GET STARTER INSTALLED THIS WEEKEND. THANKS FOR ALL THE INPUTS :seeya
Old Feb 14, 2002 | 09:02 PM
lbell101's Avatar
lbell101
Let us know how it all turns - OK
To STARTER QUESTION
