350/350 More Power Ideas?
I have a Ultra clean 69 with a 350/350 Engine, Engine has orginal Bottom end 11.1 Pistons and the original Double hump head. Engine has LT1 Cam solid lift. Roller Rockers, Torker II intake and A Holley 650 DP carb. New HEI dist. with an MSD Ingntion.
The trans is the orginal munice 4-speed with a hurst shifter added. and the rear end has 4.11 gears.
Car is quick but I have the bug for MORE POWER... and I'm looking for some suggestions, the best place to put money in the engine and get the most performance. Would a set of aluminum heads help make some noticeable power?
I imagine the engine is somewhere in the neighborhood of 400HP if the stock engine was suppose to make 350...
I want to get around 500 to 550HP.
I run a 50/50 mix of 93 Octane and 104 Octane. This is a toy and I don't mind running a premium fuel.
I plan to go through the suspension and do some udating and upgrading for better handling put want to keep the 4.11s and the 4-speed.
I looking for suggestions to get me in the 500 to 550HP range I mentioned so I can eat these new mustangs and Challengers up...
here is my ride for your assesments:
http://holtautosales.com/slone/
http://www.youtube.com/watch?v=9kEOY...e=channel_page
http://www.amerspeed.com/cgi-bin/showenginetypes.cgi
http://www.airflowresearch.com/chevy_dyno.php
BTW, Great looking car!!!
I'd note in passing that you'd likely see better driveability and more torque in your existing engine with a GOOD dual-plane vs. the Torker II single-plane.
I agree that the shortest, cheapest route to that power figure would be starting from scratch. 500 HP from 350 CID in a GEN I requires some real effort and investment. And of course if that's a numbers-matching engine you may want to set it aside. 11:1 isn't really a streetable CR even with aluminum heads - it'll run, but I suspect you're giving up power with the limited ignition advance even with the gas mix you're using. Finally, that's an old shortblock any way you cut it - I give you an 80% chance of busting the bottom end at these power levels within a relatively short time
If you're dead-set on keeping your existing shortblock, your options are kinda limited to hit that power - basically mondo heads (210cc+ runners) and a retrofit roller cam to match (.600+ lift along with that Torker II (or a better single-plane) and a 750 CFM carb. You're going to have to turn it 6000+ RPM to make 500+...and you're going to break it
Starting from scratch opens a ton of options for a streetable 500HP...but I suspect that's another thread as it's not what you're asking in your post.
This is a real generic answer, but it gives some idea of where you'd need to head.
Good luck!
Also whats the performance difference from the Heads I have to he suggested AFR 195's Will it be huge? ot just barely noticeable..?
with those pistons You could get 450Hp and even more TQ, maybe 460-480TQ , fairly easily and still not a Radical power mod. Your car is way too purty to go wild and loose driveability.
You would want a 5 or 6speed /with an OD gear to take advantage of the considerable power upgrade. Richmond ROD, or a Tremic. either will fit a 5speed OD will be easier to install.
My 2 cents worth is, AFR 195's or Brodix IK200 heads,Felpro 1094 head gasket , retro fit roller assembly Kit. to get 6-6.5K rpms , Comp Pro magnum rockers, New Comp timing Kit. New ignition, MSD pro Billet/w 7.5mm wires and 6al box, Edelbrock RPM airgap manifold , Demon 750 manual secondaries carb.
Use a "max" dropbase canister to fit under your 69 hood or better yet get a L-88 hood paint it and install to get your aircleaner up there where it should be.
Your car may handle the new power just fine or you may look at new & better Rear suspension Parts and shocks.
With the above or similar You would have the purtiest 69 around and Kick those new Power Mustangs azz into the bargain...Good luck have fun,
Vettester ,A fellow High powered 69 street owner.
Do you really believe your 5.7 liter very poor air flowing heads solid
flat tappit cam being run less then 6000 rpm ( rev limiter ) is putting out a true 400 hp. Its not very close, how do expect to take the same 350 size engine restrict it to shifting below 6000 rpm rev limit come up with 500 to 550 hp.
Did you get upgraded rod bolts on the rebuild?
If it were me (put the original motor aside) spend a little more on an upgraded bottom end, go solid roller and twist the living pee out of it. Im telling you youll love it.
Or for roughly the same money you can stroke it and bring the powerband so it peaks a little sooner and get a nice boost on torque
Page tpi421Vette in the C4 section he can get you a swinging deal on a set.
The speed shop also told me that my engine would love one of the new 4150 - 750 Holley DP. I have the old school classic 650 DP currently.
I have not had it to the track. And the reason I was saying I wanted to stay at or around 6000 RPM was to avoid breaking. It has seen 7000 RPM a few times but not planing to make a habit of it...
Honestly the Engine work was done before I bought the car so I'm going on what I was told. They did not specify if the bottom assmbly was balanced or blueprinted. Just that it was rebuilt. the heads were definately completely overhauled it has all new screw in studs, guidplates and springs, pushrods... When I adjust the lifters you can tell the heads were done right... Or at least appears to have been. The car carries good oil pressure and does not smoke at all. IT runs real good...but just like a crack addict...I want more...
If throwing a set of heads on the car and a new 750 DP will be a lot quicker maybe I just do that? Throw $2500 at the current engine and see what happens...If the bottom end does'nt hold up I could buy a great short block and put ti back together....
Jegs has a Holley Top End Kit that claims it will make 440HP
http://www.jegs.com/p/Holley/Holley-...46541/10002/-1
Thanks for all the options! this is a great help! Many thanks!
I've torn down a bunch of "really hot" engines that turned out to be collections of garbage sitting around in someone's shop.
Sounds like you've got the money to do this right - so find a good shop and tell them what you want.
in the long haul you may get caught up in a rebuild and Lose the value of a car like yours. My 69's original engine was long gone, that set me free to build it up. Cars like yours I agree with Jackson.
You should also rebuild the brakes or upgrade to wilwoods or similar.
Be prepared to spend 2 to 3 times what you think it will take to get everything right and safe.
One last comment , from me.
If your serious about Not getting embarrassed by New mustangs Or any new OEM Performance car including the asian Ricer's, youll be dissapointed regardless of what HP and TQ you make. Its all about the Gears when dealing with any new performance cars. You jump on it and pull out then 5-6 seconds later some little Japanese car is pulling away while your in 4th Gear trying not to blow your engine, and they KNOW IT
.Your Muncie wont let you embarrass any other cars exept off the line for 10 seconds. But when You shift into your .62 overdrive gear that starts making power at 3500rpms and 95mph, theyll back off embarrassed as hell as you walk away at 100, 110, 120, 130, and still pulling while under 6000rpms. Thats true glory for a C3 corvette owner.They know you dont have the old Muncie anymore!!
