Which rear differentual fluid?
Old Jul 19, 2009 | 12:14 PM
dhanurveda's Avatar
dhanurveda
2nd Gear
Default Which rear differentual fluid?
I want to replace the rear differentual fluid in a 1974 corvette.
What is the preferred fluid brand to use?
How much fluid will it take to refill it?
Old Jul 19, 2009 | 01:44 PM
Clams Canino's Avatar
Clams Canino
The prefered "brand" is 2 containers of the GM gear lube with 1 little bottle of the GM limited slip additive. JUst like factory did it.
This is not to say members here have't had success with synthetics (mostly Mobil One), but the question arises as to how much (if any) limited slip additive is enough - or too much??
Eaton (who makes our posi's) reccomends the old GM gear lube mix still - and has remained totally (and conspicuously )silent on synthetics of ANY brand. My assumption is they want to avoid "recommending" (or dissing) anything made by anyone.
-W
Old Jul 19, 2009 | 03:58 PM
thegazman's Avatar
thegazman
Default thegazman
It will take about two quarts. I don't know which gear oil is the best. I know...I was developing a slight bearing whine in the differential of my 79 (3:73). I drained the differential and used Royal Purple gear lube. The whine disappeared. Royal purple says no limited slip additive is needed with their gear lube.
Old Jul 19, 2009 | 04:29 PM
KevinZ's Avatar
KevinZ
I just changed mine and used Lucas 80w90 and a bottle of GM additive.
Took about 4 pints. (2 quarts)
Old Jul 21, 2009 | 01:17 AM
dhanurveda's Avatar
dhanurveda
2nd Gear
Does the rear have a drain plug or do I need to take it apart and replace the seal to drain the oil in the differential?
Old Jul 21, 2009 | 01:24 AM
Peterbuilt's Avatar
Peterbuilt
I guess you could do it that way, but since there is NO drain plug you can siphon the old fluid out. PG.
To Which rear differentual fluid?
