383 Windage tray
Old Jul 19, 2009 | 02:54 PM
Lee H's Avatar
Lee H
Default 383 Windage tray
I've test fit my new 383 kit and have found I do not need to trim the oil pan ledge. This means I should be able to use the stock pan. Do I need a windage tray? If so recommendation would be great. Thanks in advance, Lee
Old Jul 19, 2009 | 11:27 PM
Artsvette73's Avatar
Artsvette73
I uesd Milodon windage tray. With main studs use a rocker arm poly lock nut on the end of the stud then bolt the tray to the poly nut.
