78 suspension
Old Jul 19, 2009 | 07:06 PM
xemilliox's Avatar
xemilliox
Default 78 suspension
I have a 78 and want to upgrade the suspension but dont know where to start? Does anyone out there know of any good kits availiable for a guy with slighty above average mechanical skills? Thanks
Old Jul 19, 2009 | 07:35 PM
Duke94's Avatar
Duke94
Vette Brakes and Products makes a number of kits depending on what you want to do. They are a very good Supplier, look over their website then give their Tech line a call and tell them what you want to do with the car. 78's
Gary
http://www.vbandp.com/SearchResult.aspx?CategoryID=370
Old Jul 19, 2009 | 08:21 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Here's what I've done that has made a world of difference.
1. Composite rear spring. I went with a #330 but wish I had the #360.
2. Bilsteins Sports on all four corners.
3. Smart struts for easier alignment and IMHO a better solution overall.
4. Cut 1 coil off the front stock spring for a better stance. Better yet, go with replacement #550's.
5. Ensure your rear side yokes are not work or have excessive play.
6. Upgrade to 17" rims and tires. Quieter, smoother and handles great.
Still to do:
Install a Rack & Pinion system to replace the control valve system. I've already replaced the control valve but want an even tighter system.
Obviously, you can do more, like a composite front spring, the dual mount rear spring set up, etc. Depends on how much $ and how radical you want to go.
Old Jul 19, 2009 | 08:44 PM
Shirley1978's Avatar
Shirley1978
i did 550 coils up front and a 360lb fiberglass spring in the back.. upgraded shocks and all.. makes a BIG difference and not expensive at all
Old Jul 19, 2009 | 10:04 PM
xemilliox's Avatar
xemilliox
I have heard that the Corvette Monospring Kit for the front end is a good way to go. My understanding is that it is basically the C4 suspension in a C3. If I were to combine this with a #360 monospring in the rear do you think it would handle well?
Old Jul 20, 2009 | 12:17 PM
jb78L-82's Avatar
jb78L-82
I have made many progressive changes to my 78 L-82 4spd over the last 26 years:
Front end:
1. Poly control arm bushings, upper and lower control arms.
2. Poly sway bar mounting bushings and end link bushings, 1 1/8 in stock F-41 sway bar.
3. New 550 Coil springs, 1 in shorter, Mid America
4. Bilstein HD Shocks, poly bushings for upper mount.
5. Blue printed rebuilt stock steering box.
6. SLP 17 in direct replacement rims, 255/45/17 ZR tires
Rear:
1. 360 monospring with poly mounting bushings
2. Heim joint adjustable strut rods
3. Bilstein Sport Shocks (30% stiffer than the Bilstein HD's)
4. 3/4 in rear sway bar with poly mounting bushings, replacing 7/16 in stock bar
5. SLP direct replacement 17 in rims with 255/50/17 ZR tires, 1 in taller than 245/45/17's in front.
6. Overall stance of the car is now about 2.5-3 inches higher in the back than the front, which eliminates the rear squat in the 78/79 cars.
The overall effect is to totally transform the handling, steering, and ride of my car from the way the car came from the factory. It drives, handles, and steers like a modern sports car totally eliminating the vague steering, fair handling, and poor ride of the stock suspension. Hope that this helps!
Jeff
Old Jul 20, 2009 | 03:08 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
What?
Old Jul 20, 2009 | 10:47 PM
pauldana's Avatar
pauldana
Still to do:
This is the way to go... right here, just do it, you will be happy!
Originally Posted by TheSkunkWorks
What?
again, WHAT?????
Old Jul 21, 2009 | 12:10 PM
jb78L-82's Avatar
jb78L-82
What?
The way the car sits, rear squat is the wrong term-sorry!
To 78 suspension
