Cam selection question/ cam and engine experts
Old Jul 19, 2009 | 11:14 PM
rham's Avatar
rham
Default Cam selection question/ cam and engine experts
I am planning my 350 rebuild, I am going to rebuild the shortblock with flat top hyper pistons at around 9.5 to 1 (not building a 383- already spent to many $$$ on rebuilding rolling chassis and still have paint, interior, tires and maybe wheels to go, need to save a buck where I can!).
I am leaning towards Brodix IK180 heads or an iron 180cc head (Dart, RHS etc), Edelbrock RPM intake, Quadrajet and a good set of headers and exhaust. I want to eventually put in a 5 speed overdrive, I have 3.36 gears and using Keislers speed analyzer I will turn 1800 rpm at 64 mph so I can't go too big with the cam.
I want to use a hydraulic roller and I have narrowed down the cam to either a Comp XR270HR http://www.compcams.com/Cam_Specs/Ca...?csid=158&sb=2 or Lunati VDSC-270 http://www.lunatipower.com/Product.aspx?id=1988&gid=289. Both of these have similar .050 specs as the LT4 Hot Cam which is supposed to make 400 hp. From what I can tell the LT4 has an intake closing point of 65 whereas both of these are at 61. The Lunati has a little less overlap than the Comp and LT4. The duration at .006 for the LT4 Hot Cam is 272/ 281 so it is a little longer than the other two.
Would either of these come close to making 400 flywheel horsepower in this build?
Old Jul 20, 2009 | 06:11 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I'd say you're in the ballpark with those cams. I know your mind is set on a 350, but Scat has a stroker crank (9000 series, stronger than cast) for $200. Here's one of two dozen sources:
http://www.flatlanderracing.com/scc-cast9000pro.html
That's a little more than what prepping your stock crank will run,..though the new crank may need some prep. Good rods are out there for a reasonable price, or you may can use what you have. And you're already purchasing new pistons.
Give a 383 another look.
Back to the cam. I don't like dual-pattern cams if you're running good heads and exhaust.
More here:
http://www.camaros.net/forums/showth...e+dual+pattern
How about the Magnum 270-HR single pattern?
Old Jul 20, 2009 | 07:30 PM
rham's Avatar
rham
Back to the cam. I don't like dual-pattern cams if you're running good heads an exhaust.
More here:
I have not completely ruled out a 383, depends on what things look like in the next couple of months ($$$). I know thats the easy way to get to 400 hp.
I also thought about the Magnum 270-HR but its .050 numbers are not as good. Do you think that hurts it much compared to the newer cams. Also thought about a custom grind single pattern using Comps xfi lobes- lots of lift and from Summit they are the same price as the in stock ones.
What do you think?
Old Jul 20, 2009 | 09:27 PM
73, Dark Blue 454
With your 3.36's, the 270HR sounds perfect. Here are the specs:
http://www.summitracing.com/parts/CCA-K35-422-8/
Old Jul 20, 2009 | 09:58 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
That is a ford 351 cam.
I like the lunati and the Brodix IK 180.
Old Jul 20, 2009 | 11:50 PM
73, Dark Blue 454
Sorry,..try this. Again, it's about the biggest recommended with your gearing:
http://www.compcams.com/Cam_Specs/Ca...?csid=150&sb=2
To Cam selection question/ cam and engine experts
