What size nut/bolt for diff carrier/Batwing-82?
Old Jul 21, 2009 | 09:40 PM
Rebelrob's Avatar
Rebelrob
Default What size nut/bolt for diff carrier/Batwing-82?
Almost got the differential out. But it looks like I do not have the right socket size for the right and left batwing to frame carrier bolts.
Nothing seemed to fit. I tried them all. I think the closest was a 7/8.
Is this bolt standard or metric? Just about every bolt for this job has resulted in all different sizes , metric and standard. Very frustrating. I like how some bolts are metric and the nut its attached to is standard. Anyway, that's another thread..
The largest deep socket metric I had was 20mm and it was too small when I tried to slide it on.
If somebody has an AIM?. Not sure if they list the sizes. I have the service manual, but did not see any sizes listed.
Also these bolts are rusty scary, so I am a little concerned, been spraying them with PB blaster each day. Was going to post a pic, but looks like I am unable to.
Thanks,
R
Old Jul 21, 2009 | 10:17 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
11502604 Bolt, M14-2 x 100mm or 3.94" L Grade 10.9
The nut in case you need it: 11516074 Nut, M14-2, self-locking.
Willcox
Old Jul 21, 2009 | 10:22 PM
Rebelrob's Avatar
Rebelrob
OK. Thanks. Hmmm , Not to good with math. Can you translate. All I have is metric and standard sockets, 7/8, 3/4, 13/16, and 18mm, 19mm, 20mm.
Thanks,
R
Old Jul 22, 2009 | 01:14 AM
Gale Banks 80''s Avatar
Gale Banks 80'
I did the same Job today. I used a 13/16" Socket I allready had it for the Lug Nuts and the Spring Bolts. My car s an 80' but it should be the same.
Old Jul 22, 2009 | 04:17 PM
Rebelrob's Avatar
Rebelrob
Well my 13/16 would not fit... I actually had to use a 21mm box end wrench and back it up with a crescent wrench. So this problem is solved. I have loosened them now and will be ready to pull the rear end it out. As soon as I find a socket to fit those weird bolts on the drive shaft straps to the trans.....
R
To What size nut/bolt for diff carrier/Batwing-82?
