big block- small block
Old Jul 23, 2009 | 08:20 AM
Sho'nuff's Avatar
Sho'nuff
Default big block- small block
other than exhausts, is there any changes to be made going to a big block from a small block?
Old Jul 23, 2009 | 08:26 AM
DJCorn's Avatar
DJCorn
Front springs and hood I think
baxsom's Avatar
baxsom
search around, a lot of people here have described how to do it.
big thing is the accessory brackets.
the small block brackets wont match the big block engine.
then there is radiator, suspension etc etc
Old Jul 23, 2009 | 08:27 AM
Sho'nuff's Avatar
Sho'nuff
more than i figured.
Old Jul 23, 2009 | 09:37 AM
not a '76's Avatar
not a '76
do not do this.
a small block worth replacing a big block with would cost more than a run of the mill big block anyway.
Old Jul 23, 2009 | 09:43 AM
Attfay Elleybay's Avatar
Attfay Elleybay
I think he's wanting to go from a small block to a big block.
Old Jul 23, 2009 | 10:38 AM
not a '76's Avatar
not a '76
coffee machine is broken at work...not my fault.
Old Jul 23, 2009 | 11:57 AM
markdtn's Avatar
markdtn
Plus: Hood, a/c compressor on a late '76 and newer, etc. It can be done, but for the money now days I'd do an LS swap before I did a BB swap.
Old Jul 23, 2009 | 12:58 PM
Corey_68's Avatar
Corey_68
yes, MUCH more than exhaust manifolds.
Brackets will be the expensive and "fun" to find/buy parts. As stated, radiator, exhaust, springs, sway bar,...
Old Jul 23, 2009 | 01:41 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Motor mounts, A/C bracket, P/S bracket, Alt bracket? W/P and pulley
Cross member, half shafts, radiator,
Old Jul 23, 2009 | 07:31 PM
Big Block 69's Avatar
Big Block 69
Crossmember & half shafts??
Old Jul 23, 2009 | 08:10 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
oops, thinking of the U joints and tranny swap
and need for a trans mount.
Come to think of it, the dia of half and u joints size is bigger like LT1
Old Jul 24, 2009 | 08:56 AM
Ganey's Avatar
Ganey
75-79 already has the larger half shafts & dual ex. crossmember.
Mainly accessory brackets, rad., exhaust, springs if not FE-7.
Old Jul 24, 2009 | 09:19 AM
auavette's Avatar
auavette
Just finished my 76 with a 496 and a 8-71 blower.
If it wasn't for the blower the change would have been a lot easier.
Did change the trans also to a TH-400 and the yoke to fit the drive shaft. Otherwise just the brackets. Try a march system.
Old Jul 31, 2009 | 10:51 AM
auavette's Avatar
auavette
Take a look at these pictures
http://forums.corvetteforum.com/memb...8-img-0876.jpg
http://forums.corvetteforum.com/memb...1-p2210036.jpg
I do not have the a/c.
I had to go to the 7 inch brake booster to clear the valve covers, but with the origonal gm valve covers you would have no problem with the original booster(at least in my 76)
Old Jul 31, 2009 | 11:06 AM
63Nova's Avatar
63Nova
Not to mention that parts for a big block are about twice the price for a small block. I found all this out when I built my first 496.
Old Jul 31, 2009 | 11:11 AM
DRIVESHAFT's Avatar
DRIVESHAFT
I think you made a few more changes than were actually necessary.
To big block- small block
Old Jul 31, 2009 | 11:19 AM
vintage-racer's Avatar
vintage-racer
Default Do the bigblock..
All brackets for p/s and or a/c and alt. can be purchased as a kit brand new from zip or paragon and are not that expensive. The motormounts are interchangable. The only tricky part is pulleys, do your research. There is no replacement for a bigblock thru sidepipes ,I've had highstrung / high compression small blocks....the bigblock is music you can feel plain and simple.
Old Jul 31, 2009 | 11:23 AM
mtcraigco's Avatar
mtcraigco
Brackets and radiator are the biggies.
March has a very nice bracket kit for not much more than scrounging the originals
A rad kit will set you back 700 to 1000, but I don't know that I'd run a BB without upgraded cooling unless it had one factory. Could be wrong though.
BB swap = more $ (and effort) than small block upgrades, but is WAAY cool!
Old Jul 31, 2009 | 11:27 AM
auavette's Avatar
auavette
That is true but mainly due my desire for a 8-71 blower.
Even the powersteering has a remote tank, which is not necessary if you are just putting a BB in it
