79 wont start...
Old Jul 25, 2009 | 12:02 AM
kdlopez01's Avatar
kdlopez01
4th Gear
Default 79 wont start...
Hey everyone I am new to the forum... I have a stock 1979 corvette and it just stop running... I had a new distributor installed about 5 months ago and it ran great, but after my last trip walmart it would not want to start it will crank but not start? People have told me its the spark plugs I am just not sure... any suggestion? Appreciate all your help thanks!
Old Jul 25, 2009 | 03:23 AM
73StreetRace's Avatar
73StreetRace
Possible causes : No fuel or no ignition :
Check fuel level in the carb fuel bowls. If not OK, look for clogged fuel filter or fuel line or defective fuel pump ( or empty fuel tank ).
If OK, remove a spark plug wire, use some adhesive tape and stick the extremity of the wire at a short distance from a grounded metal part of the engine but without touching it.
About 1/4 to 1/2" is OK. Have someone crank the engine and see if you get a visible spark jumping from the wire.
Don't do this with the carb open !!!
If OK, remove one ( or more ) spark plug to see if it's not fouled or wet.
Old Jul 25, 2009 | 03:36 AM
kdlopez01's Avatar
kdlopez01
4th Gear
Thanks for the help but I am real noob to carbs how do I check the fuel in the bowls? Also where is the fuel filter located and how do i change out the fuel pump if neccessary?
Old Jul 25, 2009 | 03:51 AM
kdlopez01's Avatar
kdlopez01
4th Gear
i guess a good question is there any where i can get a free manual online to download and read?
Old Jul 25, 2009 | 03:52 AM
73StreetRace
Many infos here :
http://forums.corvetteforum.com/c3-t...-and-tips.html
and here :
http://www.bob2000.com/carb.htm ( even if this page is a little more Holley oriented )
Manuals here :
http://www.tocmp.com/manuals/Carbs/R...QJet/index.htm
You can also make a search on this forum with the key words "Q-jet" or "quadrajet" or "adjust float level"
Old Jul 25, 2009 | 04:26 AM
73StreetRace
All right ! I made part of the job for you :
This is a quote ( Lars Grimsrud ) :
"You have to pull the top of the carb off to set the float level. With the top removed, remove the big phenolic spacer that covers the area around the needle/seat. Hold the float hinge clip firmly seated and push down lightly on the float where it contacts the needle. Measure from the top of the float bowl to the top of the float at the rear edge of the float. Float level should be .375” for a street-driven car using a 1968 – 1974 carb; you can run it at .250” for racing. Early Q-Jets (1968-1972) can be successfully run on the street with the high float level, but you may see some fuel saturation of the air horn gasket with associated gas fumes. Later carbs (1975 and newer) do not run well in street applications with the high float level – run the 1975 + carbs at .420” on the float level. Adjust the float level by removing the float and bending its lever arm. Never raise the float level by forcing the float against the needle/seat to bend it – this will damage the needle."
Old Jul 25, 2009 | 07:25 AM
kdlopez01's Avatar
kdlopez01
4th Gear
my corvette does not have a fuel filter correct?
Old Jul 25, 2009 | 07:34 AM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
How many miles not that it matters. Could be the timing chain. I replaced mine on my L82 at 52900 miles. The chain was slapping the side cover. My car has the dual roller very sharp teeth that wear sooner than the single roller. Twice as fast in fact.
Old Jul 25, 2009 | 08:27 AM
73StreetRace
It's possible you don't have a fuel filter.
But then it would be a good idea to have one...
Old Jul 26, 2009 | 07:10 AM
82collectersvette's Avatar
82collectersvette
just a suggestion, spray ether into the carb, (starting fluid) if she cranks its not spark or anything else its fuel supply, if she doesnt crank than it could be spark, could be timing chain, could be alot of things
Old Jul 28, 2009 | 10:29 AM
73StreetRace
But first, maybe you should make sure it's not ignition related, before tearing apart your carb
Always remember : most carb problems are ignition problems
To 79 wont start...
