You really don't need to worry too much about detonation until you get up past 9.5:1 with premium gas.
I didn't wanna hijack the head thread, so I'm starting here. What kind of compession ratio is considered "safe" with pump gas, for that matter "regular" pump gas?
The partial engine (427 SBC) I'm looking at for Phase II - claims 10.1 and will run on pump gas. I was already a little skeptical and the above post seems to confirm this. What's the safe compression for regular gas?
Assume when you say "regular" gas your talking 87 octane!? If yes then I think 9.5:1 may be a problem. I have 10:1 and run fine on 93 Gasahol with gobs of advance in my 383....but wouldn't try anything less.
My guess would be 9:1 or less.....I'm sure more expert opinions will follow.
Cam plays a major role in it. Ihave seen 11:1 motors on pumps gas with no problems. I have also seen iron headed 9.5:1 motors rattle like crazy. I run a 10.7:1 AFR aluminum heads with a big solidcam with no problem on pump gas. There is no set compression that is safe. To many variables.
You can generally run about 0.5 ratio more with aluminium heads over cast heads for starters....
Also, as cam duration increases, you can run higher compression ratios.
The compression ratio stated on engine buildups is the static compression. The issue with detonantion is related to the dynamic compression ratio.... that is, the actual compression achieved when the motor is rotating, and the bleed off during the overlap phase is taken into account.
Also, higher octane fuel allows for more compression too.
so choose your engine buildup depending on what your primary design goals are.
I'm not running *any* cam yet... I'm looking at the World Products 427 SBC and I'm kinda skeptical of thier claims at 10.1 / 1
Note that I'm a long way from Phase II, I just want to learn early to get a plan on paper.
-W
My original roller cammed 427 SBC was something like 10.4 with 64 cc heads. I always ran the local 91 octane. My present 434 is 11.7 and it run fine on 91 with a larger roller cam.
