advance spring selection
Old Jul 27, 2009 | 06:24 PM
painterman52's Avatar
painterman52
Default advance spring selection
Which springs from a mr. gasket recurve kit will get me all in at about 2500 rpm? I`ve got an accel dist.
Old Jul 27, 2009 | 07:45 PM
tonyv123's Avatar
tonyv123
I sure someone here can tell you the colors, but I've only got my dist. set up by trial and error. Like one silver, one gold, hook up timing light, run it up till it doesn't advance any more, and note RPM at that point. Make sure you make note of which way the weights are installed, and get them back exactly the same way. (This is if you are also changing the pin bushings.) I got mine mixed up and had a time figuring it out.
