Idler pulley
Old Jul 28, 2009 | 11:41 AM
nutovette's Avatar
nutovette
Cruising
Default Idler pulley
Does anyone have a diagram of the idler pulley on a '69 427 w/ps. The layout of my fan belts is that I have one belt going from the outer pulley on the crank to the outer pulley on the water pump and to the inter pulley on the p/s unit, then on the outer pulley on the p/s unit to the pulley on the alt. that leaves the inter pulleys on the crank and the water pump which is to have this idler pulley to tension that belt, but I can't seam to find any pictures, diagrams, on how this idler is to bolt up. Any help would be greatly appreciated.
Old Jul 28, 2009 | 02:58 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I chose not to install buy the $$ idler pully on my BB setup.
and it seems just fine without it, do you have A/C ?
Old Jul 28, 2009 | 03:59 PM
Duke94's Avatar
Duke94
Here's a scan of a 71-72 BB with PS from the Corvette Parts Book. Don't know if it's the same as 69 or not.
Gary
Old Jul 28, 2009 | 04:44 PM
nutovette's Avatar
nutovette
Cruising
Thanks Gary, it looks the same and the fan belt no. is the same all I need now is how to connect the idler pulley to the engine.
Old Jul 28, 2009 | 04:56 PM
nutovette's Avatar
nutovette
Cruising
No AC. but without the idler the first pulleys are empty because there is no way to tension the belt between the crank and the water pump so I figured I might as well figure out what the idler connects to and go ahead and install it. There lies the problem I can't find any info. on the bolt up.
Old Jul 28, 2009 | 06:22 PM
Duke94's Avatar
Duke94
A search found a few previous threads.
Gary
http://forums.corvetteforum.com/c3-t...-69-427-a.html
This one shows the idler pulley bolt up.
http://forums.corvetteforum.com/c3-t...er-pulley.html
You must not be the only one with BB idler pulley issues as there were a ton of threads that came up when I searched for "idler pulley".
Old Jul 29, 2009 | 02:21 AM
southern_vette's Avatar
southern_vette
there is a bracket that bolts to the block. This bracket has a bearing where the idler rotates on the bracket. Some of the venders have pictures of both the idler and the bracket.
To Idler pulley
