U-Joint Sizes on 82??
Old Jul 28, 2009 | 01:32 PM
Rebelrob's Avatar
Rebelrob
Default U-Joint Sizes on 82??
Got the half shafts and main drive shaft off the car. Seems to me the main drive shaft u joints look to be a different size than the half shafts.. Little smaller..
Problem, is I am being told by the auto part stores is they carry one size u joint for all 6 u joints (main and half shafts). Is this correct?
I have read some posts, where GM put different size u joints on different years. Not sure if that had to do with 4 speed vs automatic or not.
Can I use the same size u joint for all 6 or are they definately a different size from the half shafts vs the main shaft?
Thanks,
R
Old Jul 28, 2009 | 01:39 PM
tonyv123's Avatar
tonyv123
Heres some:
http://www2.dana.com/expertforms/dek350.aspx
Old Jul 28, 2009 | 02:11 PM
DRIVESHAFT's Avatar
DRIVESHAFT
They are not all the same size.
The halfshaft joints are larger.
Old Jul 28, 2009 | 02:34 PM
Rebelrob's Avatar
Rebelrob
Yep, that is what I thought.. But I figured the auto part stores were smarter than me. Maybe not in this case....... Need to figure out a plan b and try to get the right u joint size. It had spicers on as the OEM part, but they seem to be very tuff to find. If I cant walk into a store and buy them, I'm not interested in ordering.
Old Jul 29, 2009 | 08:44 AM
Hootisit's Avatar
Hootisit
I just recently did all the u-joints in my 82. I have FE7 gymkhana suspension in the rear. The u-joints on the halfshafts are 1 3/16 dia bearing caps, the drive shaft is 1 1/16 dia cap, if I recall correctly. So they're probably like mine...
Old Jul 29, 2009 | 11:01 AM
MN-Brent's Avatar
MN-Brent
The 82 halfshafts got the larger 1350 U-joints and the driveshaft got the 1310 U-joints.
In 80-81 year cars, only the manual transmissions got the larger 1350 U-joints and the automatics got the smaller 1330 U-joint in the halfshafts. They stepped it up in 82 I assume due to the fact that the 700R4 transmission has such a low first gear.
Check out Duntov Motors website 80-82 driveline page for good info on the sizing of U-joints.
Spicers are the best, but hard to find. I can also recommend BruteForce U-joints and have used them for many moons with good success. Here are the 82 parts list:
BruteForce models are:
1-0153BF: 1310 U-Joint (Driveshaft)
2-0053BF: 1350 U-Joint (Half-shaft)
Spicer models are:
5-785X for driveshaft (1310 series)
5-799X for half shafts (1350 series)
B.
To U-Joint Sizes on 82??
