Weak Secondary Opening
Old Jul 28, 2009 | 10:49 PM
SD71VETTE's Avatar
SD71VETTE
Default Weak Secondary Opening
Need help with a secondary issue on my carb. I have read many of trhe previous threads on this issue and I have followed all the directions but I still cannot get my secondaries to open very much. I have adjusted the timing correctly. I replaced the 750 Holley with a 670 Holley Street Avenger and I installed the weakest spring. I also replaced the throttle cable with a new Lokar cable to ensure WOT. Below are a couple of pictures. One shows the paper clip and the amount of secondary action and the second shows the Lokar install. Any suggestions would be greatly appreciated. Thanks!!!
Old Jul 28, 2009 | 11:34 PM
TimAT's Avatar
TimAT
When you press the pedal to the floor, are the primary throttle blades opening all the way? Have someone hold the pedal down and open the secondary plates by hand and make sure they're not binding or hanging on something. It's doesn't take much drag to stop them- that little vacuum pot has very little pull.
Old Jul 29, 2009 | 05:16 AM
73StreetRace's Avatar
73StreetRace
Air cleaners can affect the opening point and rate, because the diaphragm is vented to the atmosphere and it "sees" the vacuum drop accross the air cleaner. It's a delicate balance of forces. The secondaries are opened by engine demand.
On the other hand, a too large vacuum-operated secondaries carburetor can often be used without spolling drivability, but the secondaries may not open entirely. Your engine is probably not using the maximum cfm capacity of your carb.
Old Jul 29, 2009 | 05:23 AM
baxsom's Avatar
baxsom
torn vacuum diaphram?
Old Jul 29, 2009 | 05:33 AM
73StreetRace
If you have a relatively thick gasket under your carb, and/or too much tightening torque on it, it can slightly bend the secondary shaft, preventing the vacuum diaphragm to operate correctly.
Old Jul 29, 2009 | 11:58 PM
SD71VETTE's Avatar
SD71VETTE
Thanks for all the input. I will check out some of the suggestions to see if they help. The vacuum diaphragm is in good condition. I replaced it on the 750 I took off and I checked this one as well. If you all think of any more let me know. If I can't get this to work maybe I'll switch to a QJ.
Old Jul 30, 2009 | 07:35 AM
baxsom's Avatar
baxsom
thats a lot of effort just to find out that if your engine didnt have enough vacuum to open a holley it probably wont open a qjet either.
qjets only open as far as the engine demands. that is why they are so versatile and the same cfm was used on a large range of engine. id wager that on some of the smaller engines it was put on the back two barrels hardley ever got cracked open
ps
also check the diaphram to make sure the check ball is in it. then make sure that there is a good seal between the diaphram and the carb body. sometimes that little cork O ring comes out
To Weak Secondary Opening
