What horn notes were stock?
Old Aug 1, 2009 | 07:42 PM
70454's Avatar
70454
Originally Posted by CCrane72
That may be a normal sound. The '72's only have one horn and it is pretty anemic.
cc
Ha...the one that's left is strong. The weak one is out. I'm gonna blast it with 12V and make it sing a high note like Prince.
I did get the horn button to work. It's being difficult, but it works. I screwed with the relay wires. Miller Time now. Thanks.
I'll check for that ground location in a bit. The wire with the loop is there, it just needs a new home.
Old Aug 1, 2009 | 11:57 PM
CCrane65's Avatar
CCrane65
I sent him an email but he hasn't responded yet. He's working 12 hour night shifts this week so he may be a little slow to respond.
Will get back to you as soon as I can.
cc
Old Aug 5, 2009 | 07:45 PM
CCrane65's Avatar
CCrane65
Here are a couple of pictures of the ground wire that runs in the same area as the horn wire. It is screwed into a hole just to the left of the center of the nose support. There is a star washer between the loop and the nose support. I was told to make sure you didn't put the washer on top of the wire.
First picture is a closeup:
And this one gives a little perspective:
cc
Old Aug 6, 2009 | 11:43 AM
70454's Avatar
70454
Thanks for the pics. I've been trying to get a J hook that size from Paragon. I'll keep looking.
Old Aug 6, 2009 | 11:45 AM
CCrane65's Avatar
CCrane65
Try Dr. Rebuild.
cc
Old Aug 6, 2009 | 12:59 PM
70454's Avatar
70454
Try Dr. Rebuild.
cc
Thanks. They had them. Wiring Harness Clip Set, 5pc.
