line lock...
Old Jul 31, 2009 | 02:42 PM
flynnd_33's Avatar
flynnd_33
Default line lock...
how do u set up a line lock with the porportioning valve in a 1980 vette.....
i bought the jegs line lock and i was just installing it... does it go after the valve or before it....
maybe someone can draw a diagram for me...?
thanks
Old Jul 31, 2009 | 03:35 PM
BKbroiler's Avatar
BKbroiler
I have a Hurst line lock in my 77. As I recall, I installed it between the master cyl and the proportioning valve the way the instructions indicated. It works like it should, brakes are good too.
Old Jul 31, 2009 | 04:03 PM
Manuel Azevedo's Avatar
Manuel Azevedo
After, the purpose is to lock the front wheels only.
Old Jul 31, 2009 | 04:05 PM
tshort's Avatar
tshort
CI 7-8 Veteran
I'm not too familiar with the later model C3 brake system but on my '69 there is a dual master cylinder and you can put it inline from the MC to the prop valve on the front wheel line. That's what I did. I located the unit on the fender under the MC. Works great!
Old Jul 31, 2009 | 04:20 PM
gkull's Avatar
gkull
I did a write up with pictures if you dig back in time on line locks
Old Jul 31, 2009 | 04:25 PM
Manuel Azevedo
Your right!
Old Jul 31, 2009 | 04:50 PM
jotto's Avatar
jotto
did a lil digging...
http://forums.corvetteforum.com/c3-t...brakeline.html
the link you posted to is out of date now though I think.
Old Jul 31, 2009 | 07:12 PM
flynnd_33's Avatar
flynnd_33
mine also has the split banks in it too.... and i would like to do it just like g skull did it.... nice and simple.....
roll control to a lil line then right back into the system....
if u do it like this does the brake light come on?
Old Aug 1, 2009 | 03:51 PM
Richard454's Avatar
Richard454
It would not turn on your brake lights. However- you could put a relay powered the same as the line lock- switched to ground and tap the wire at your e-brake-and it would light the brake light in gauges up -so you'd know it's on.
Richard
Old Aug 1, 2009 | 03:57 PM
toddalin's Avatar
toddalin
I have mine (Hurst Roll Control) replacing the front brake "T" fitting. A single line comes out of the M/C and feeds directly to the lock. The lock splits the lines for the left and right front brakes. It's barely visible on the frame just at the front header.
Old Aug 1, 2009 | 04:04 PM
toddalin's Avatar
toddalin
Richard
Even easier than this. You can just wire the brake lights in parallel with the line lock switch. You've got to physically hold the line lock switch to keep the lock engaged so this would also keep the brake lights engaged whenever the lock is in operation.
You would want to put a diode on this wire so that when you engage the brakes at the pedal on a regular basis, the +12 volts does not feed back down this wire, get into the line lock wire, and turn on the line lock when you don't want it on.
Old Aug 1, 2009 | 04:43 PM
Richard454's Avatar
Richard454
I'm talking about the parking 'BRAKE' indicator light in the Tach gauge- This way YOU know it's locking/engaged/working-not the people behind you.
Richard
Old Aug 1, 2009 | 05:51 PM
toddalin's Avatar
toddalin
Richard
No difference except instead of a wire to the brake lights, it would go to the parking brake light. You would still want the diode so that when the parking brake is engaged turning on this light, it doesn't feed back through the wire and engage the line lock.
As for a visual indication, my Hurst came with a light to tell when it is engaged, but I never mounted/connected it. I know that when I hold the button and the car can't move, it's engaged.
Old Aug 1, 2009 | 07:19 PM
BKbroiler's Avatar
BKbroiler
I just looked at mine, and you're right, line lock is after the proportioning valve.
Old Aug 1, 2009 | 11:22 PM
Richard454's Avatar
Richard454
Sorry- won't work- the Brake Light in the Tach gauge sees +12 volts when the ignition is on-Won't light up till it sees a ground through either the parking brake switch or the brake master cylinder switch.
Here's a simple diagram- no diode needed because there is nothing to feedback -The relay only completes the circuit as if the parking brake is pulled up (or bad master brake cylinder)-Only thing pulling the e-brake up when the line lock is on (and gauge brake light) would be a double ground on the circuit-and perhaps the bulb might glow a little brighter.
Two wires go to a ground, one wire to the line lock and one to the e-brake wire-Done.
Richard
Old Aug 2, 2009 | 06:55 AM
Fishndude's Avatar
Fishndude
I was thinking of doing a line lock too.. I have never owned a car that had such good weight transfer and hooked up so good with the stock suspension, even on the street with 10.5" radial T/A's....
Old Aug 2, 2009 | 01:12 PM
toddalin's Avatar
toddalin
Richard
Got it.
Except for the parking brake light, the wiring diagrams show the lights in the cluster need +12 volts to work whereas the parking brake already has the +12 volts and needs a ground to work.
The wire and diode would still work if a different cluster light (e.g., high beams or both turn indicators, with two diodes) were selected as an indicator instead of the parking brake light.
Also the parking brake light could be used if the line lock activation switch was a double pole single throw with one of the two poles dedicated to grounding the parking brake light. In this case the diode wouldn't be necessary either.
Actually, to be PC, line locks are now known as "hill holders" and wiring the rear end brake lights up to the line lock is not a bad idea.
To line lock...
