ez out info
Old Feb 15, 2002 | 03:36 PM
daniel77350's Avatar
daniel77350
Default ez out info
How do they work? Can I get a broke/rusty bolt out with one? How much do they cost? where do I get one?
I have broken the thermostat housing bolt off flush with the intake...I need to get it out...If I have to drill and retap the bolt, my car will have to go up to a shop, because I don't have the tools/skill to do that...
Daniel
Old Feb 15, 2002 | 03:43 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: ez out info (daniel77350)
Easy outs are not all that difficult to use but they dont always work.
You can buy them at Sears or any other quality hardware store. You drill down into the center or the bolt pop in your easy out apply pressure and back it out.
Sometimes it works and sometimes it dosent. It's hard to tell....
They also make some reverse cutting drill bits that help the process along a little bit. They are very hard to find though.
Good luck!
[Modified by Mike69, 2:50 PM 2/15/2002]
Old Feb 15, 2002 | 03:45 PM
RatMat's Avatar
RatMat
I wish you good luck. I had the same problem last year. I tried using an EZ-Out and it broke off in the bolt. I decided to pull the intake and take it to a shop. One of the intake manifold bolts near the water pass through snapped while I was removing the manifold. Once the manifold was off I noticed my intake valves were gunked up with oil. Since I had been fouling some plugs I pulled the heads for a rebuild and manifold bolt removal. When I removed the exhaust manifolds I noticed they were cracked near the front bolt hole. An easy thermostat change resulted in rebuild heads, brazed/cleaned exhaust manifolds, and a repaired/cleaned intake manifold not to mention a lot of fun. Better Luck to you!
Old Feb 15, 2002 | 03:47 PM
daniel77350
Default Re: ez out info (RatMat)
hmm...I'll let my dad do the ez out...he said he's done one before...plus if he brakes it off I can have him pay for the machine shop visit. :eek: Did I say that outloud? :blueangel: :blueangel:
Daniel
Old Feb 15, 2002 | 03:55 PM
Edzred72's Avatar
Edzred72
An easy out looks like a drill bit, but the spiral flutes on the shaft are a reverse twist. Depending on the size of the bolt and the easy out you intend to use, you drill a specific size hole down into the bolt. Care must be taken in your case not to drill too deep, but deep enough to get the "meat" of the e-out down into the bolt. After the hole is drilled, you reverse twist the e-out down into the bolt. As you reverst twist (counter clockwise) the e-out bites into the bolt and backs it out. Use plenty of penetrating oil first... You can buy an easy out kit just about any Home Improv store. Includes 4-5 sizes of drill bits and E-out's. But beware.. there are some cheapies out there that will break quite easily. I get mine individually from Grainger through work, and they are of excellent quality. Good Luck :cheers:
[Modified by Silvr77, 2:00 PM 2/15/2002]
Old Feb 15, 2002 | 04:03 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: ez out info (Silvr77)
An easy out won't work on a rusted bolt. it will only get the easy bolts out, thats why it called easy out :smash:
Seriously, the ONLY time I've had an easy out work is when I broke a bolt by over tightening it! They have NEVER EVER worked on rusted bolts.
Old Feb 15, 2002 | 04:07 PM
daniel77350
Default Re: ez out info (427V8)
well I mean it busted because my thermostat housing was leaking so I went to tighten it a little turn, and snap...I just assume its rusted because when I put it in, it went in with a fight(wasn't cross threaded)...I'll probably have to have it drilled and tapped. :cuss :cuss
Daniel
PS. If I take the car to a mechanic that can drill and tap, how much do you think Im looking at?(I'd have him drill and tap the screw, check my work, and make sure its running good before I get it back).
Daniel
Old Feb 15, 2002 | 04:58 PM
427V8's Avatar
427V8
Well if it was turning at all then it might work. I was talking about bolts that are rusted into one big blob
Old Feb 15, 2002 | 05:01 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
Use a reverse drill bit to drill the hole for the easy out. Sometimes the drill bit will grab the bolt and get it out before you need the easy out.
Old Feb 15, 2002 | 05:14 PM
Edzred72's Avatar
Edzred72
...I'll probably have to have it drilled and tapped. :cuss :cuss Daniel
If the bolt was removed and turned recently, an e-out probably will work. If not.. then take it in to be drilled. What have you got to loose?? :D :D
To ez out info
