Alright so when I bought the car the guy said the ac worked which really meant that the heater was stuck in the on position and only blows out by the floorboards. I got the heater turned off by taking it to a mechanic and he used a manual valve to turn it off? then he said that I needed a new ac control unit. I bought a new unit off of ebay and installed it this morning. Now the low med and high work flawlessly but the ac still only blows out by the floorboards, can anyone help? is this a vaccuum leak? where should I look? thanks!
C3 air is controlled by vacuum- when you switch the control in the dash from MAX to DEF can you hear anything hissing? It's possible the source from the intake manifold is disconnected. (located usually at the same port the headlights get thier vacuum).
there is a vacuum valve on the control head too. With the connector removed, start the engine and check that one of the ports has good vacuum, then take a small hose and apply vacuum from that to the outer ports and see if doors move and re-direct the air.
Most of the factory manuals have good diagrams of the vacuum system. That will help get your troubleshooting figured out.
The water shut-off is vacuum controlled too- another clue to a vacuum related problem.
On at least later C3 the problem is that heater is the default position (no vac. or vac. leak) due to being designed in the north. Vent should be default.
1) The vac. line from engine is damaged from heat - a small plastic tube that goes in below the hood alarm switch into wiper valley. Replacing most of engine side w/ hose will fix. OR
2) The vac. switch itself is not switching due to vac. leak as the usually plastic rivet is not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or lube w/ a thin layer of white lithium grease to fix.
3) If you have a heater, the small vac. tube to heater hose valve underhood probably also needs replacing. Block w/o heater.
PS The design problem comment is not intended to be offensive to any of our northern friends.
Reason: deleted 'or vasoline' to fix.
ok I have found two hoses that are disconnected the first hooks up to the thermostat housing, the plastic piece is broken so guess I get to replace that.
Ganey-no.1 on your list.... that hose looks fine but where it connects in the engine bay there are two ports for vaccuum lines and it looks like one of those should go to the egr valve? that piece is broken off as well could either of those be causing the ac to not function?
Maybe the one to manifold, cap or plug it. It seems to me the original manifold fitting was metal.
After that when testing, reving the engine which will increase vac. when the throttle closes may help get it going again. If not press the switch halves together w/ fingers.
The switch is in the console attached directly to the selector for Vent/(A/C)/Heat/Defog.
I just remove 1 front screw from a side console panel for access.
good luck with your car and the ac. i just moved from temple a year ago . i really like it down there. look around and youll find a few c3 guys runnun around town. i used to be one of them.
yeah I have seen a black chrome bumper running around and then I know another guy in belton its a nice area thanks... by the way I either hooked up all hoses or plugged them off and to no avail. Finally I just pulled out the whole dash and propped the door open for the top vents as a temporary fix. I would still like to know what it is exactly that opens that door? it seems like there is a spring trying to hold it shut? is the door vaccuum driven or is it mechanical? thanks guys!
Doors are all vacuum that are spring loaded one way or the other. The vacuum plls them to the "alternate" position. You do have vacuum at the switch in the console? If not then it's either unhooked or broken under the hood.
ok guys I know its been a little while but I found that one of my vac probs was the heater control valve, replaced it with a new unit and ran the vac line. ac will blow cold for about 3-4 min then start blowing really hot again guess its the door inside the dash, is this door on the driver or pass side?
Is there a way that you know of that I can permently close the flap/door at the squirrel gage to direct the air through the a/c vents. I just dicovered I have fiber glass damage on the inside of the finder where the flap/door bracket fasten to the finder.
By the way its a 79 L82 bought it a year ago.
Your distribution box has 2 flapper doors. One is the mode door (defrost, vent, floor) and the other is the temp door. Based on your HVAC settings these doors open and close either fully or partially.
Look at the box on the passenger side near the floor and center console. Operate your heat, A/C, temp thumb wheel. You should be able to hear, see and feel the doors moving as you change the selection. The doors are operated by a vacuum that moves a lever that moves the flap.
If the temp door or mode door are not moving, disconnect the vacuum supply line and apply your own vacuum to see if the doors will move. Also check the end of the vacuum line to see if you can feel a vacuum when you change modes or temps.
As mentioned you would then need to find out why it isn't getting any vacuum. If it is getting a vacuum maybe the door is stuck, the vacuum valve is defective or the mechanical lever is rusted.
