rear suspension too high
Old Aug 1, 2009 | 05:14 PM
barbs '69 resto's Avatar
barbs '69 resto
Account disabled by request 8 Feb 2010
Default rear suspension too high
My original leaf spring was tired and had to be replaced. The thing is the ride hight is extreme now. There is 6+ inches of clearance between
the top of the tire and the wheel opening. Anyone have this problem and if so how did you correct it? Thx for the help.
Old Aug 1, 2009 | 06:19 PM
GTR1999's Avatar
GTR1999
Common problem with all aftermarket springs. I used several steels, 7 & 9 and all required 8" spring bolts to bring the rear body down. This was with Eaton spring,canadian & mexican springs. I don't like or use glass springs but some had the same problems with them.
Old Aug 1, 2009 | 07:04 PM
blue427's Avatar
blue427
Here's how I solved that problem.I have the f-41 suspension(7-leaf),brought an after market and sat too high so I took 1 leaf out.started with the smallest one.I wound up taking the next to last (largest) one out.6 leaves and it sits fine and handles well.Keep the leaf you take out so if it ever settles in you can put it back.Easy job,less then 45 minutes start to finish.You might want to start off with removing the next to last one,thats probably the one that will let it set right.
Old Aug 2, 2009 | 07:35 AM
jb78L-82's Avatar
jb78L-82
I have had a VBP rear 360 NON TAPERED monospring in my F-41/gymkhana suspension 78 since 1987 and never had a problem. i am sure that you have reasons for using a OEM type rear 7 leaf spring but IMHO and others, the steel spring is way inferior to a composite monospring:
Composite monosprings offer the following:
1. Weigh 7 lbs versus 50 lbs for the steel
2. Offer a superior ride versus steel
3. React much faster than steel
4. Will not sag over time but some do splinter with time. They generally do not wear out if they are not abused.
5. Composites do not squeak like steel and generally are very quiet.
6. Composites do require a very high quality shock like Bilsteins or Koni's and will be very bouncy with standard issue shocks.
Old Aug 2, 2009 | 08:23 AM
Ganey's Avatar
Ganey
If you just installed & haven't rolled, it will settle some.
I have the factory high performance sus. & switched to VB&P rear spring in the early 80s & used the long bolts to install.
Driven very hard & no problems w/ VB&P spring.
Old Aug 2, 2009 | 08:35 AM
dar322's Avatar
dar322
St. Jude Donor '12-'13
Make sure you know the correct spring width and number of leafs for your car. Seems the 2.25" wide 7 leaf has a much more drastic arc in the spring, wheras the 2.5" 9 leaf seems to have less of a bow to it.
Old Aug 2, 2009 | 06:34 PM
barbs '69 resto
I probably should have mentioned the spring is a stock 9 leaf replacement from Triangle spring purchased from Vett brakes.
I'm not pleased with the ride hight at all. I don't understand why the aftermarkets can't reproduce parts correctly like the originals.
Thanks for the help.
I really appreciate it.
To rear suspension too high
