Dumb Fuel Pump Relay Question
Old Aug 1, 2009 | 09:08 PM
78Vette-SA's Avatar
78Vette-SA
Default Dumb Fuel Pump Relay Question
What is the difference between a single pole 30amp and double pole besides 10 amps? I see they come in different flavors but was curious of the advantage of a double pole over a single pole or what additional use it has.
Old Aug 1, 2009 | 09:24 PM
TimAT's Avatar
TimAT
Kind of tough without any way to draw a picture,
A single pole is just a simple on- off switch. One wire feeds from the source of power, the other goes to whatever you want to turn on/off.
A double pole can control 2 separate things independently of each other- power too. Like 2 switches that are side by side and only have one handle to operate it.
The relay coil is the handle.
Did that make any sense?
The amp rating is how much current the switch contacts can handle without sticking together,
Got lucky- this thread has a single pole relay diagram:
http://forums.corvetteforum.com/c3-t...-question.html
Old Aug 1, 2009 | 09:28 PM
72LS1Vette's Avatar
72LS1Vette
I could be wrong but the single pole relay will route the input to a single output whereas the double pole relay will route the input to 2 outputs. If you are just wiring a fuel pump relay the single pole should be all you need. The double pole relay is probably rated at a higher amperage due to the multiple outputs.
Rick B.
Old Aug 1, 2009 | 09:32 PM
TimAT's Avatar
TimAT
Lots of stuff about switches and such:
http://en.wikipedia.org/wiki/Switch
and :
http://en.wikipedia.org/wiki/Relay
To Dumb Fuel Pump Relay Question
