Lower Coolant Hose Spring
Old Aug 2, 2009 | 10:36 AM
mikep3's Avatar
mikep3
Default Lower Coolant Hose Spring
Where can you by a lower coolant hose spring?
Auto parts stores sell a hose for $9 to $15, but no spring. Corvette parts guys want $50+ for the hose.
Old Aug 2, 2009 | 10:50 AM
BHRIG's Avatar
BHRIG
You can buy the spring at PEP BOYS....
It is located in the HELP section(Those red cards with all the things we need,but can't find)
Good Luck
Old Aug 2, 2009 | 11:28 AM
mikep3's Avatar
mikep3
Good Luck
I just tried the P-B site and found it impossible to get anywhere but locked up in their select a store routine.
But I will stop by and check with them today in person.
Old Aug 2, 2009 | 11:40 AM
Ironcross's Avatar
Ironcross
you dont need a spring, the system is pressurized. Get a gates hose unless your stuck in the numbers crowd
Old Aug 2, 2009 | 12:00 PM
mikep3's Avatar
mikep3
I was having a cooling issue at 3000 RPM/70 MPH. I have sealed the radiator, will be adding Mr. Gasket 180 thermostat and spring to inlet hose to try and solve the problem.
If that dose not work, it will mean a radiator flush or replacement, unless I missed something.
To Lower Coolant Hose Spring
