Another rear seal!!!!
Old Aug 4, 2009 | 08:51 PM
ImBatman's Avatar
ImBatman
Default Another rear seal!!!!
As always with this car. Fix one thing and another pops up. It appears that my second rear main seal is leaking and it got worse when I put the valvoline 50 weight racing oil in it. Does this make since??? The second time with the seal I followed TimAT's direction's to the letter. Did not leak a drop and now it is all over the place!!!!
Could it be something like an over filled pan??? That is wishful thinking as it only starts after the motor is warm and driven down the road. Seems to be able to sit an idle all day long with no leak.....
Old Aug 4, 2009 | 09:39 PM
TimAT's Avatar
TimAT
How much oil did you put in it? I have a 5qt pan + the 1 for the filter 6qts total. Unless you have a big pan, 5 quarts is the normal fill including the filter. I'm getting ready to put together a new direction sheet too. The one I did some time ago I've pulled out. Another member sent me a rather heated email telling me I had used "his" pictures of the rear seal package from GM. I'm putting together another sheet. It'll be the same exact steps, with maybe a few more details.
Did you put a spot of RTV at the corners of the pan? And if you pull the oil fill cap off while it's running, can you feel any pressure if you cover the hole with your hand?
Old Aug 4, 2009 | 10:23 PM
alswagg's Avatar
alswagg
why are you running 50 wt oil? We use 15W40 in all applications for Marine use where we have engines running 5000 to 6000 rpm all day long happily. Very rare occurance of any oil leaks. Allan
Old Aug 4, 2009 | 11:35 PM
ImBatman's Avatar
ImBatman
It seems that the leak did become more pronounced when I put the 50 wt in it. I went with this because of the high zinc content. Is this oil so thin it is blowing past the seal????
Tim,
I have the one peice pan gasket and I did not put any sealer on it. Mistake? Also I am not running a pcv. Both VC's have the filter type oil caps that you wash and reuse.
Wade
Old Aug 4, 2009 | 11:56 PM
noonie's Avatar
noonie
It helps to use a pcv setup or something positive.
I had no leaks on an 75000 mile engine I hooked up a test gauge on by closing off the pcv and now the seal leaks a bit.
Don't start it up again, just for your reading info.
Old Aug 4, 2009 | 11:58 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Actually straight 50 weight oil is very thick. The Valvoline VR1 oil is also available in a 10W-30 if you care.
Old Aug 5, 2009 | 06:21 AM
TimAT's Avatar
TimAT
with noonie- a PCV running on vacuum will keep your crankcase pressure down where the seals have a chance.
50w oil is pretty thick for an engine with .003 clearances.
And oil can seep past the corners of the pan where it makes the turn for the block to co over the timing cover and over the rear cap.
Old Aug 5, 2009 | 08:51 AM
mrvette's Avatar
mrvette
YES, no matter what, if you don't use RTV black by permatex....sold in 5 buck tubes any parts house.....you going to have a leak in them corners, never seen a engine that didn't...
Old Aug 5, 2009 | 09:27 AM
...Roger...'s Avatar
...Roger...
Are you sure your oil leak is not coming from above the rear main seal ? There are many more places that can leak and appear to be the rear seal. I had one in awhile back that a guy had knocked the rear cam plug out.
Old Aug 5, 2009 | 10:02 AM
ImBatman's Avatar
ImBatman
Guy's after further inspection it is "possible" that it is the pan gasket leaking and not the seal. It is wet where the hump is over the rear cap and it looks to be below the rear cap but hard to tell for sure.
Here is my plan,
-I should have used rtv on a 1 peice rubber pan gasket???
-If I need to have RTV on it where exactly should it be applied??
- I should be able to drop the pan enough without removing steering linkage correct?
-Connect pcv back up on passenger side and leave the filter style cap on drivers.
-Change the oil to a lower weight Valvoline R that still has the high zinc content.
Thanks All!
Old Aug 5, 2009 | 10:21 AM
noonie's Avatar
noonie
You might find this interesting.
When I bought my 77, the oil was clean and felt pretty thick when cold. At least 80° ambient temp here in Florida.
Had the valve covers off, engine cold, ready to adjust the valve running.
Started the engine, to warm it up and noticed that there was absolutely no oil coming off the rockers at all.
It took at least 5 to 10 minutes for the oil to start coming off the rockers after the engine had warmed up enough.
There never was any noise with no oil, tappets were as quiet as any other engine.
Went ahead and adjusted the lifters and changed the oil to 10w40 and left it overnite to cool.
Started the engine cold the next day and there was oil at each of the rockers immediately.
From this observatin, I doubt running straight 50 is a good idea.
Old Aug 5, 2009 | 11:11 AM
GeorgeS's Avatar
GeorgeS
Here is my plan,
Thanks All!
Blackrat, If you have the PCV connected to vaccume and the filter cap on the other side you will create a vaccume leak! It will suck the air from the filter through the PCV. My 68 was set up like this when I got it and it wouldn't idle till I closed (replaced) the filter cap.
Old Aug 5, 2009 | 11:40 AM
tshort's Avatar
tshort
CI 7-8 Veteran
You had something wrong with your setup then. That is the prefered method for a street car and most problems are actually solved by using this method. If you only have a pcv on one side and no open breather on the other side then you can create a vacuum in the system which can cause the same types of problems as having positive pressure. The open breather on the other side let's the system maintain zero pressure when situations exist inside the motor that give low pressure. When pressure is high then the pcv 'sucks' the pressure out where a breather only setup will not bleed off that pressure and the pressure tries to find other weak points like seals and gaskets to leak its pressure.
Old Aug 5, 2009 | 11:43 AM
Artsvette73's Avatar
Artsvette73
Here is my plan,
Thanks All!
A one piece gasket only requires a dab of rtv in the four corners.
Right buy the rear main cap where it meet the block. In the front where the timing cover meets the block.
PVC valve on the drivers side and the breather on the pass.side.
At best remove the idler arm and you can remove the oil pan
Old Aug 5, 2009 | 12:12 PM
BKbroiler's Avatar
BKbroiler
There is no reason not to be using a pcv setup on your engine.
Old Aug 5, 2009 | 12:53 PM
GTR1999's Avatar
GTR1999
Wasn't there a thread here or elsewhere on the different seals avail today? I don't recall 100% but seem to think there were 2 or 3 rear seals from fel-pro?
Old Aug 5, 2009 | 09:18 PM
Tom's 79's Avatar
Tom's 79
DWncchs,
That's what I am thinking may be happening with mine. I just got done replacing the rms using the double lip offset seal and Tim's good instructions and there is still a leak. I cleaned the area up again today, I'll check tomorrow if it is coming from the rear cam plug. The plug is sticking out of the block 1/16-1/8". The first area to get wet with MOTOR oil is inside the bellhousing.
To Another rear seal!!!!
Old Aug 5, 2009 | 09:41 PM
TimAT's Avatar
TimAT
That's correct. I know of at least 3 different SBC seals. All are under the same number at GM parts, but I think Fel-Pro has them listed separately. I haven't researched BB seal so I don't know if they have more than one.
Old Aug 6, 2009 | 12:48 AM
noonie's Avatar
noonie
Fel-Pro BS40013 Blue Stock replacement, Silicone, offset
Fel-Pro 2900 Grey High performance Silicone
Fel-pro 2912 Red For Racing, Fluoroelastomer, Offset (Best)
Old Aug 6, 2009 | 03:27 PM
ImBatman's Avatar
ImBatman
The last one I put in was the Blue. This is a BBC also. As far as the cam plug I would not be able to see that unless dropping the trannie BH and cluth\PP would I. And if it were that it would have leaked from the begining and not just started? I guess this is the bad thing about making multiple changes at a time. Hard to figure which one may have caused an issue.
On another note what PCV would you all recommend? I have a cap with one integrated into it but have heard before that the individual ones are prefered.
