stupid question
Old Aug 4, 2009 | 10:28 PM
coolcoupe's Avatar
coolcoupe
Default stupid question
ok here goes got my motor back in and its a sb 202 heads hoged out and air gap rpm intake demon carb roller cam and i hooked up my pvc to the same line as the brake boost and now my idel out of gedar goes way up to like 1500 rpm any help ?
Old Aug 4, 2009 | 10:41 PM
Sho'nuff's Avatar
Sho'nuff
do not hook those up on the same line. Brakes need full manifold vacuum. Not sure if that will help your idle though.
Old Aug 4, 2009 | 10:46 PM
coolcoupe's Avatar
coolcoupe
do i haveto run a pvc ?
Old Aug 5, 2009 | 12:08 AM
BB72's Avatar
BB72
I would
Old Aug 5, 2009 | 12:16 AM
DRIVESHAFT's Avatar
DRIVESHAFT
What are the cam specs? Are you using the stock torque converter?
Big cam + tight converter = major rpm drop when car is put into gear
To stupid question
