AC compressor replaced - Will not take freon
I took my 2004 GMC truck in for service and they said they found a small leak in the ac after I reported a problem of it going full heat sometimes. They added dye and refilled. I noticed on the way home that the ac was not very could. was going to take it back but didn't have the time so I used my gauges and found high pressue to be 350 so I let some out to get down to 250 and now it cools great.
I would start by putting the gauge on the high side and let it go back down until you begin to feel cold air and compare this to the correct pressure for outside temp (it's on the web). Don't forget to put a fan in front of the condensor or your readings can be off.
