yet another jetting question
Old Aug 6, 2009 | 06:29 PM
bondoboy's Avatar
bondoboy
Default yet another jetting question
I have a Holley 3310-4 750 on my 350. I know, some people think it's too much, but it's been done before. I have 9.8:1 compression with domed pistons, lunati cam with 262/268 duration and 468/ 489 lift. I am using hooker comp headers and a low rise weiand dual plane (that's all that will fit for now). The carb comes with 72 primary jets and a 6.5 power valve. I have gradually moved up to 80 primary jets. I tried reading the plugs, but they always look white. Does today's gas make it hard to read plugs? I always run 92 octane. I do not have the money for an a/f meter right now, so would anyone with a similar combo be able to give me an idea on what jets would be close? I just don't want to hurt the engine. It seemed to be more responsive with the factory jetting, but the white plugs made me think it was lean. Thanks for any help.
Old Aug 6, 2009 | 07:40 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
Do yourself a favor and find a chassis dyno and spend some time on it. Instead of the "hit or miss" method you are currently using, The cost of spending time on the dyno to get your components "dialed in" will be more than worth it. There should be one around you somewhere. Even if you had to drive a while to get to a shop with a dyno to get it right...don't you think that would be worth it.
Just a bit of advice from a guy who deals with customers who are trying to do what you do right now. And I end up putting it on a dyno and get it tuned to peak performance. A
A guy in Boulder Colorado will have a different set up than a guy in Miami Florida even with the same exact engine. Altitude, air density, and other factors change the way the engine may need to be set-up. So using someone elses jet sizes may or may not work. I am taking this to the extreme, much like a drag racer who travels will have to change things to get the car the best for the current conditions.
Look into it, dyno testing is really not that expensive in relation to you damaging your engine due to testing without proper equipment which can often be a dyno.
"DUB"
Old Aug 6, 2009 | 07:57 PM
bondoboy's Avatar
bondoboy
Thanks a lot. I'm just trying to get a ballpark setting for now. I intend to get an a/f meter soon.
Old Aug 6, 2009 | 08:18 PM
tsw71's Avatar
tsw71
Most likely, the 72's that it came with will be pretty close to correct if not a bit rich. Anything below 2500 rpm is controlled by the a/f idle screws in the primary metering block. As many people that have tuned with wideband a/f setups have found, the slightest move with those screws can make a huge difference.
Old Aug 6, 2009 | 08:51 PM
bondoboy's Avatar
bondoboy
Thanks for the help!
Old Aug 6, 2009 | 09:25 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Mine were white too but I know I was cruising in the 13:1 range as well as idle. So I think it is the gas, I was using Sunoco 94 I have since changed and will look at the plugs again
Save up and get wideband so you know where you are at. 80 primaries is good for 555 nitrous motor
Old Aug 6, 2009 | 10:05 PM
bondoboy's Avatar
bondoboy
Thanks, I was wondering why I couldn't get any color on the plugs. I really need an a/f meter!
Old Aug 6, 2009 | 10:12 PM
MotorHead's Avatar
MotorHead
Thing is as posted above, your idle mixture screws have more affect on cruise than your main jets, believe me I know. Just a slight turn on one screw can make your idle mixture jump from 13:1 to 14:1 and this carries on into your cruise as long as you are below about 2500RPMs.
So until you get a wideband and can "see" what is going on I suggest putting the 72's or 74's back in and tune the idle mixture screws to get you highest vacuum reading. That's about all you can do for now and make sure you are running the right plugs and you timing isn't too far advanced
Old Aug 6, 2009 | 10:31 PM
bondoboy's Avatar
bondoboy
I have my timing set at 36 mechanical and 52 total as the experts recommend. I increased the compression from 8.5:1 to 9.8:1 so I went with one step colder plug than the motor used originally.
Old Aug 7, 2009 | 07:54 AM
Fishndude's Avatar
Fishndude
52 total
I've had some pretty stout small blocks in my days but never have I ran one more than 41.. The motor in my Vette right now was dynoed at 452hp with 10-1 and a BG Mighty Demon 750 and I have my timing locked out at 36 with the weights tied down and the vacuum can unplugged.
Old Aug 7, 2009 | 08:43 AM
billla's Avatar
billla
St. Jude Donor '14
I agree that something approaching 1970 LT-1 factory jetting (also with a 3310) is probably right in there. I have an Innovate...and it's saved me untold dyno dollars as well as teaching me a bunch about carbs. Reading plug color is a bit of a lost art these days, but I would step back from your colder plugs right now.
Your timing is right on, and you definitely want both mechanical and vacuum advance for a street-driven SBC.
Old Aug 7, 2009 | 10:26 AM
gerry72's Avatar
gerry72
Originally Posted by Fishndude
52 total
He's referring to total as including vacuum advance. It's engine-dependent, but if you're running under well 9:1 compression, it's very normal to see over 50 degrees with initial, centrifugal, and full vacuum advance.
Old Aug 7, 2009 | 11:09 AM
73StreetRace's Avatar
73StreetRace
Most Holleys ( let's say 90% ) are already jetted on the rich side right out of the box.
With a 750 cfm carb, you're probably running most of the time on the cruise and idle circuits, so changing the main jets has only little or no effect on the spark plugs color.
Big carb = big venturis = small air speed and carb signals with small engine displacement.
I'm pretty sure your carb is already rich enough with the stock jets.
The speed of incoming air is simply not sufficient to create enough vacuum to suck fuel from the openings... This is probably why you're running lean.
Old Aug 7, 2009 | 01:40 PM
bondoboy's Avatar
bondoboy
Thanks for all of the help.
To yet another jetting question
