Old Feb 20, 2015, 05:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Radiator Cleaner Flush
Old Aug 17, 2009 | 09:45 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
white vinegar will clean it.
you do have the heater running right?
Old Aug 18, 2009 | 12:04 AM
noonie's Avatar
noonie
You left out an important part, and that is to neutralize the acid when finished.
Clr contains mild organic acids, vinegar is also an acid, as is oxalic acid, but they need to be neutralized.
Typically, if the radiator/heater core springs a leak, with the proper GM proceedure, then they were on their last legs anyway.
