fuel pump pushrod
Old Aug 8, 2009 | 01:45 AM
coolcoupe's Avatar
coolcoupe
Default fuel pump pushrod
can any one tell me do u have to use a special fuel pump rod on a roller cam or can u uses the same as a regular cam
Old Aug 8, 2009 | 10:03 AM
Artsvette73's Avatar
Artsvette73
Hydraulic roller or solid roller?
Old Aug 8, 2009 | 11:18 AM
FB007's Avatar
FB007
No, you don't need a special rod.
Old Aug 8, 2009 | 01:33 PM
mvette76's Avatar
mvette76
you should use a fuel pump rod with a brass end so it wont eat the cam and damage it! they are a cheap a lot cheaper than your cam!!!
Old Aug 8, 2009 | 01:50 PM
S489's Avatar
S489
any cam will be able to run mech fuel pump. take a look at the lobe for the pump, it's barely a lobe; compare to valve lobes. you can push the pump lever with your bare hands; try that with valve springs. the load on the pump cam is just really low comparitively.
inspect the end of the pump rod for any flaws; lube b4 installation.
call your cam mfgr for confirmation/clarification of these things for peace of mind . . . good luck
Old Aug 8, 2009 | 04:02 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Cam manufacturers tell you to use a rod with a bronze tip if you are running a billet roller cam. Otherwise the cam can be damaged.
Old Aug 8, 2009 | 08:49 PM
S489's Avatar
S489
thanks driveshaft, i agree, that's the really the kind of info coolcoupe needs from the cam mfgr he has chosen. i started to add qualifiers, but the list get long and with the if/then's and i type too slow.
coolcoupe, not all roller cams are made made the same, best to place a call to the mfgr . . . thanks
Old Aug 8, 2009 | 10:06 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Some should be careful what advice they pass on, full roller valve train with billet cam is very expensive. I actually use a roller fuel pump push rod on my billet solid roller cam
Old Aug 8, 2009 | 10:24 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
Does the bronze end go toward the cam or the fuel pump?
Old Aug 9, 2009 | 12:24 AM
FB007's Avatar
FB007
They will also tell you to use a bronze distributor gear. Also a POS.
Old Aug 9, 2009 | 12:36 AM
gingerbreadman1977's Avatar
gingerbreadman1977
do what you want Fb but my crane roller told me to use the bronze fuel pump shaft so i did it. they dont say to use one for the hell of it, its for a reason. it also called for a particular type of distributor gear but my msd had it already.
jeffery bronze end to the cam
forvicjr's Avatar
forvicjr
comp cams has a polymer dist gear thats impregnated with some sort of lube, seemsn to be a good product though ive never used it,i have had durability probs with the bronse gear.
Old Aug 9, 2009 | 12:39 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Steel billet like used on most serious solid roller cams needs a bronze tipped pushrod. The tip goes on the cam. A stock pushrod will destroy the steel billet cam.
If you have one of the cast core cams (like Comp uses)..or Austempered iron ones you can use a stock one...but the tipped one will work too.
Best dist gear choice is to have cam made with an iron dist gear so you can run stock gears.
JIM
Old Aug 9, 2009 | 12:41 AM
MotorHead's Avatar
MotorHead
When you order a billet cam you tell them you want a pressed on iron gear and this will work with any stock or aftermarket distributor.
My small base circle billet solid roller cam has a pressed on iron gear. You can order it with any profile you want and CCams will make it for you in about a week and they only charge about 40 bucks extra over their off the shelf cams which have that concrete look to them
Old Aug 9, 2009 | 01:30 AM
FB007's Avatar
FB007
Billet camshafts have been around alot longer than bronze tip pushrods.
I have seen many bronze distributor gears fail, but never a melonized GM gear.
Next you guys will want bronze tipped lifters on a billet flat tappet cam.
To fuel pump pushrod
