Power Antena
Old Aug 9, 2009 | 04:47 PM
garretttpe's Avatar
garretttpe
Default Power Antena
I have a 80 vette with power antena, It stays up all the time (not original radio). I removed the antena and jumpered some wires and it goes up and down fine. Here is the problem that i dont understand.
I have 3 wires green, white, grey. when hot is to green and touching the other 2 wires the antenna goes up. then I have to ground green and hot to the other 2 wires antenna goes down. I am confussed. I would expect that 1 wire woulod be hot and the other to would be up or down.
can somone please help me with the scematic so I know how to wire it into my radio (previous owner was a hack at wiring)
Old Aug 9, 2009 | 05:02 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
You have a relay mounted under your hand brake cover for the power antenna. The signal wire from your radio goes to it and with the adding and removing power or ground (depending on your aftermarket radio) to the relay causes the antenna to go up and down.
You will see the three wires (green ,gray,white) that plug into one side of the relay. The other plug is coming from the radio area . I do not have the wiring diagram here at home but I believe they are (orange ,yellow, black) but I wont swear by it.
I can let you know tomorrow, unless someone else has it already posted.
"DUB"
Old Aug 9, 2009 | 06:51 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Power antenna...
up
green (+)
gray (-)
down
green (-)
white (+)
As stated, that's the function of the relay to switch the combinations.
The yellow wire coming from the (original) radio is the trigger, the orange wire coming from under the dash near the radio is constant hot which provides power to lower the antenna when the key is off.
I think the relay for 80 is under the center armrest all the way to the back as in the 78/79s, but it may be in the jack storage compartment.
Look for a relay with white, green, gray, orange, yellow, and black(ground) wires and you found it.
Old Aug 10, 2009 | 05:25 PM
Former Vendor
The orange wire is the CTSY/CLK fuse (20 amp) which powers your interior lights and many other items. Make sure that the orange wire going to the relay has power and the black wire going to teh relay is grounded. The yellow wire is the wire that is coming from the radio and switches power on and off to the relay to make the antenna go up and down,.
"DUB"
Old Aug 10, 2009 | 10:29 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Aftermarket radios it creates a wiring issue with the relay. You'll need to figure a way around this.
Here is the schematic and the relay location.
Willcox Inc.,
Old Aug 10, 2009 | 10:59 PM
Grumpy 427's Avatar
Grumpy 427
Mine is just dangling buy the hole, it looks like a couple of lower brackets are required to hold it in place? anybody have any pictures of what they look like so a guy can make them? i have one still bolted to the body, but it is no where near the antena?
Old Aug 10, 2009 | 11:14 PM
0Willcox Corvette
Former Vendor
Grumpy. . .
Here you go! Number 2 in the picture.
Old Aug 10, 2009 | 11:16 PM
KapsSA's Avatar
KapsSA
Here's how a FACTORY late79-82 antenna looks mounted. Top mounts to the fender with the bezel, bottom is a simple L bracket....
Old Aug 10, 2009 | 11:22 PM
Grumpy 427's Avatar
Grumpy 427
Ok Thank you very much guys i will give it another look and see what the heck is not lining up?
Old Aug 10, 2009 | 11:38 PM
Grumpy 427's Avatar
Grumpy 427
Something is a miss here? The hole in the fender is too small for the shaft to fit through. But i dont think it is supposed too? It looks like the factory Antena, all hard wiring, no disconnect clips.
Old Aug 10, 2009 | 11:42 PM
KapsSA's Avatar
KapsSA
Just the chrome bezel fits through the fender hole, the antenna mast tube jambs up against the bottom of the fender.
Looks like you got everything there that you need.
Old Aug 10, 2009 | 11:44 PM
KapsSA's Avatar
KapsSA
Is your mast tube jambed up THROUGH the hole in the fender?
Old Aug 10, 2009 | 11:49 PM
Grumpy 427's Avatar
Grumpy 427
No it is butted up to the fender there, but you can see the lover bolt doesnt line up?
Old Aug 10, 2009 | 11:54 PM
KapsSA's Avatar
KapsSA
Don't know what to say...
Can you move the bracket up?
Has the integrity of the inner fender been changed? I see a big crack in your top pic.
Old Aug 11, 2009 | 12:12 AM
Grumpy 427's Avatar
Grumpy 427
Not to worry, i will make it happen. there was room to move the bracket up. worst case i will make a new one that works.
To Power Antena
