polly body mount install.
Old Aug 9, 2009 | 05:17 PM
Grumpy 427's Avatar
Grumpy 427
Default polly body mount install.
Has anybody installed them? there are no directions that come along with them, and i am just guessing as to how to install them? and pictures on which way the tapered end goes and the washers would be great. By looks of things, you need to install them all on the body first?squeeze them together over the sleeve?
Old Aug 9, 2009 | 06:08 PM
Grumpy 427's Avatar
Grumpy 427
Well after looking out in the garage again, i think they should go like this? my frame is still at the sand blasters so will double check when i get it back.
Mount number one . obviously with the frame inbetween the 2 mounts.
Then 2&3 2 behind the kick panel and 3 in front of the rear tire. will be both the same.
And #4 the extreme rear will be the same as #1 almost.
If anybody sees anything wrong here please let me know? Once i get this done i think i will send the vendors instructions so the next poor A$$hole doesnt have to struggle without any help.
Old Aug 9, 2009 | 07:32 PM
Grumpy 427's Avatar
Grumpy 427
ttt nobody has done this?
Old Aug 9, 2009 | 08:48 PM
redwingvette's Avatar
redwingvette
I helped a friend do it on his car. This is how the ones he had went in
Old Aug 9, 2009 | 08:53 PM
Grumpy 427's Avatar
Grumpy 427
Ok so now i have seen 2 ways to do this? so the hockey puck mounts go between the frame and the body? not the tapered ones? I wonder if i can find the manufacturer to find out what the intent was here for these mounts? Thanks for the reply i do appreciate it.
Old Aug 9, 2009 | 08:57 PM
Grumpy 427's Avatar
Grumpy 427
only 1 good picture of the new mounts in this write up, and it shows the opposite of what you did.
http://www.europeancorvette.com/html...eplacement.htm
Old Aug 9, 2009 | 09:05 PM
redwingvette
The hockey pucks will be the ones to hold the load so they need to be in between the rocker channels and the frame. The tapered ones hold the bolts in place on the brass tube, as the bolts are tightened the bushings will compress together some.
Old Aug 9, 2009 | 09:28 PM
Grumpy 427's Avatar
Grumpy 427
Is that on all 8 points?
Old Aug 10, 2009 | 01:22 AM
Grumpy 427's Avatar
Grumpy 427
Did some looking and found the correct way to put them in. Here is the link, hope this will help the next poor guy who needs help.
http://www.digitalcorvettes.com/foru....php?p=1419248
Old Aug 10, 2009 | 01:27 PM
Grumpy 427's Avatar
Grumpy 427
For those that need this info here is the correct procedure i found.
Mounts 1 and 4 the Hockey puck mount goes in between the body and the frame with the tapered mount under it.
Mounts 2 and 3, the hockey puck mount goes between the body and the frame. The tapered mount goes in the kick panel and in the wheel well opening with the tapered end down.
This is for the polly mounts, the 4072 is the hockey puck and the 7019 is the tapered bushing.
http://www.energysuspension.com/asse.../pdf/17050.pdf
Old Aug 10, 2009 | 11:09 PM
Grumpy 427's Avatar
Grumpy 427
New development. Looks like i have To make some large flat washers to support the holes now. Anybody else suffer this rust issue?
Old Aug 11, 2009 | 02:33 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
The large Diammeter, shorter height, goes in-between the body and the frame.
On all mounting points. 69VETT
Old Aug 11, 2009 | 10:20 AM
Grumpy 427's Avatar
Grumpy 427
Yeah i got it figured out.
Old Aug 11, 2009 | 01:27 PM
redwingvette
Mine were much worse so i cut out the rocker channels and welded in repair channels. You might get away with just the inserts.
body mount repair
To polly body mount install.
