About 2 weeks ago I noiticed my fuel gage barely bouncing and removed the connection at the tank, cleaned and replaced,didn't help.
Yesterdays ride it would bounce from full to 1/2 full mark(the tank had just been filled up). I'm the kind of guy that if it's on my car I want it to work, no matter what it is, so again I ask for more help. Thanks
Wow!! what a detailed piece of instruction, thanks for the tip and to Willcox Corvette.
Will try this out tomorrow and let you know. Thank you again ED
Well it's doing it again (bouncing), I guess I thought the ground wire worked, have R&R the wire and doesn't help, should I go to the instrument cluster? Thanks ED
