Brake bias ratio
Old Aug 10, 2009 | 10:31 PM
forvicjr's Avatar
forvicjr
Default Brake bias ratio
anyone know what the factory brake bias is for the 81,thinking of installing an adjustable one under the dr seat. in ex 60/40,70/30??
Old Aug 10, 2009 | 10:44 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
It doesn't really matter what the factory bias is.
It matters what you have done to the car in the way of tires, brakes and suspension.
You SHOULD be running a Prop valve. Adjust it untill the front brakes lock up just before the rear brakes do. The Vette comes stock with too much rear brake.
Even running 275 rear tires and 255 fronts people still frequently need to back off the rears.
Old Aug 10, 2009 | 10:54 PM
forvicjr's Avatar
forvicjr
thanks, im goin to remove the prop valve completely and use the adjustable one since there known to stick anyway. was goin to leave it close to the stock setting. but now i guess im goin to take some rear brake out... thanks again
To Brake bias ratio
