Where's the HP???
Old Aug 11, 2009 | 10:54 AM
Stickboy97's Avatar
Stickboy97
Default Where's the HP???
In what year did GM detune the C3 and take the guts (HP) out? I know the late 70's & early 80's were detuned but when did it start, 75?
Also, is there any way (cheap way) to get the HP back? What did GM do to these lovely cars that made them so "eco-friendly"?
Shane
Old Aug 11, 2009 | 11:04 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
It was the 70's version of global warming, a combination of a supposed oil shortage and environmentalists doing their thing turned them into smog mobiles with lots of HP eating modifications starting in 72 I believe
You can reverse the gross indecency, look at my sig and pull out your wallet
Old Aug 11, 2009 | 11:05 AM
gerry72's Avatar
gerry72
Compression ratios were dropped in '71 to pave the way for low and no-lead fuel with their lower octane ratings and to address NOX emissions. The rating standard changed in '72 from gross to net measurements. When you put these two factors together you have a 1970 350/300 that, in 1972, is now a 350/200 (loss of 30hp from the compression drop in '71 and the change in how the engines were rated in '72. The power didn't actually change in '72, just the way it was measured) There really wasn't much detuning following '71 and the power differences were relatively minor. The addition of EGR in '73, cat converters in '75, and some minor ignition and camshaft updates is the bulk of the detuning.
Old Aug 11, 2009 | 11:14 AM
cv67's Avatar
cv67
St. Jude Donor '05
No cheap way to power.
Old Aug 11, 2009 | 11:15 AM
Mike Ward's Avatar
Mike Ward
In a word, no. Easy enough to do, just not cheap.
Old Aug 11, 2009 | 11:20 AM
Jims66's Avatar
Jims66
Other than the Blue Flame 6 cylinder engines........., the 1975 Corvette (base engine) was the lowest HP rated Corvette ever (190HP ??). Ask me how I know this wonderful little fact................
Old Aug 11, 2009 | 11:32 AM
gerry72's Avatar
gerry72
I thought the '75 L48 was rated at 165hp?
Old Aug 11, 2009 | 11:49 AM
Stickboy97's Avatar
Stickboy97
Thanks for the quick responses!
So if I'm planning on a driver for my wife there isn't much diff between a 71 & a 82 based on HP, or power in general? She doesn't need a 454, probably a 350. It'll be a weekend warrior/sunny day driver. I think she likes the early 80's models, lots of curves and a few more creature comforts but with all the Eco HP reducing crap of the late 70's early 80's I was worried about buying her a car with no get up and go. She likes the power of my C6 but wants the look of the C3, and I have no desire to drop a crate engine in for her.
Are there things you can remove or add to increase the power some?
Old Aug 11, 2009 | 11:51 AM
Mike Ward's Avatar
Mike Ward
195HP in '74, up 5 from '73.
Stickboy97's Avatar
Stickboy97
With these changes can you add a cam, change the ignition, exhaust, etc. and add power, decent power, to say an 82?
When I say cheap I'm talking a few thousand or less.
Old Aug 11, 2009 | 12:10 PM
Mike Ward's Avatar
Mike Ward
For a few thousand you can buy a nice crate engine.
Old Aug 11, 2009 | 12:51 PM
OregonVette80's Avatar
OregonVette80
Shane
The detuning actually happened EOY 1970. By 1975 the Vette was by many accounts only around 150-160HP. But good news, by 1979 the HP ratings actually started increasing again to peak out the C3 era with the 1980 L82 (HP ratings are 230 or 235, depending on the publication).
Engine code: ZBC denotes the L82 350-cid 235-hp V-8 9.0:1 compression engine. In 1980 only the automatic transmission was available. They all (even the CA car) had a standard four-barrel carburetor.
Old Aug 11, 2009 | 02:59 PM
Jims66's Avatar
Jims66
You're right......... 165HP. It was awhile ago and my mind must have inflated the number to make me feel better. I stand corrected. Wow, 165HP............. I think the L82 was 210HP...... but I'm not sure.
Old Aug 11, 2009 | 03:31 PM
midyearvette's Avatar
midyearvette
yep!! and be money ahead, as an aside, the 80-81 had camshaft problems...constantly wiping lobes and taking a loong time to do so...good luck
Old Aug 11, 2009 | 03:42 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
a step is to undo the things GM did.
IE, up the C/R and advance the timing.
I see you are in Tex. Lucky you. They are less strict on mods.
Here in Ca, if it cam with fac specs, you better conform.
I am limited by a base timing of 6deg and can't get any facts
on how much C/R I can run and still pass NOX.
Old Aug 11, 2009 | 04:04 PM
Jims66's Avatar
Jims66
You'll get a warranty too.........
Old Aug 12, 2009 | 07:58 PM
Stickboy97's Avatar
Stickboy97
If you drop a crate engine in one of these (est. $3k) how much does it cost to have it all installed? If it costs $5k to do the whole thing and get it up and running I may be better off looking for an early model C3 with a good strong engine, driver... not a show car by any means.
To Where's the HP???
Old Aug 12, 2009 | 08:21 PM
Attfay Elleybay's Avatar
Attfay Elleybay
You can get a 400HP (real world probably closer to 350) topend kit from Jegs or Summit for under $2000
Old Aug 12, 2009 | 08:23 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Buy / build / operate / upkeep, HP is not all that cheap anymore even if you do all the work.
Old Aug 13, 2009 | 01:59 AM
shank0668's Avatar
shank0668
Sucks that 78 top engine only had 220 hp.
